New Technicolor Profile Is Amazing at DVinfo.net
Canon EOS Crop Sensor for HD
Old April 30th, 2011, 12:49 PM   #1
Since I downloaded it and install it on my 7D and 5Dmkii, I have not stopped playing with it. It was designed for the 5D, but I cannot tell the difference on the two camera.
I hope to have some video examples up later today. Comparing the Flat versus the New Technicolor Picture Style.
Here is the link to how to get it on your camera.
April 2011 Vincent Laforet’s Blog ... on-5dmkii/
Thomas
Thomas L. Phillips - Director/Editor/DP - www.tstreetfilms.com
Canon 7D, Canon 50mm f/1.4, Tamron 17-50mm f/2.8, ULTRAcompact Rig, DFocus V2
Thomas L. Phillips is offline   Reply With Quote
Old April 30th, 2011, 10:35 PM   #2
Re: New Technicolor Profile Is Amazing
Uploaded the technicolor profile in my 7D. Shot a test video with the recommended profile settings. Color graded with the S-curve lut using Red Giant in AE CS5. I'm quite impressed with the result. Beautiful color, saturation and contrast. Definately an improvement from the flat profile I have been using. Thanks for sharing.
Dave Murray is offline   Reply With Quote
Old May 1st, 2011, 06:05 AM   #3
Check out this thread to see my first test and a few thoughts on its strengths-
http://www.dvinfo.net/forum/canon-eo...ial-tests.html
Ben Denham is offline   Reply With Quote
Old May 1st, 2011, 07:40 AM   #4
Right on! I'll probably download this sometime today and test it out with my 7d. I convert my files with Neoscene which does have a very slight gamma change from the original .mov file, so I wonder how much different it'll look.
Kelly Huffaker is offline   Reply With Quote
Old May 1st, 2011, 10:19 AM   #5
Will this work on a 550D?
"Your world is all these elements; of light and sound, of taste, smell, and touch. Woven together in many dimensions on the fabulous loom of your brain. Your brain; the most complicated thing in the world, which you yourself grew...without even thinking about it."
Kent Frost is offline   Reply With Quote
Old May 1st, 2011, 10:31 AM   #6
I can confirm that the Technicolor profile works on the 550D/T2i just fine! Did a few quick shots around my desk and all works exactely as it should on the 550D...
Ruben Kremer is offline   Reply With Quote
Old May 3rd, 2011, 02:27 PM   #7
just used it on my 60D and it works
Lee Tamer is offline   Reply With Quote
Old May 3rd, 2011, 05:28 PM   #8
How did you get it to load in the 60D? I can't get the EOS Utility to open up the Technicolor profile, it simply won't let me click on the open file icon.
Mikey Williams
Down To Earth Productions
Mikey Williams is offline   Reply With Quote
Old May 6th, 2011, 06:17 AM   #9
I really want to test out the new technicolor profile but I'm skeptical to install it on top of magic lantern. Using a T2i. Anyone out there have any success with this?
Luke Gates is offline   Reply With Quote
Old May 6th, 2011, 02:29 PM   #10
All that we're talking about here is a Picture Style. It should not in any way effect, or be effected by, Magic Lantern. The first thing to do is download the latest versions of the Canon software for your computer - EOS Utility, etc. Once you have done this, follow the simple instructions that come with the Technicolor Picture Style.
Good luck!
Jeremy Pevar is offline   Reply With Quote
Old May 7th, 2011, 09:15 AM   #11
Really? It worked fine for me, I followed the instructions on the site and had no problems. it showed up on my camera as a user defined setting
Old May 7th, 2011, 11:05 AM   #12
Make sure your dial on the actual camera is turned to the C1, C2, or C3 setting that you are going to save the profile on. Also remember to save the settings in camera once its installed.
-burk
Jason Burkhimer is offline   Reply With Quote
Old May 7th, 2011, 03:38 PM   #13
Yes, works just fine. I have used Magic Lantern with the Profile. See this vimeo post for test with t2i and 5D, in which I used the false colors to set exposure in first place:
Chris J. Barcellos
Old May 7th, 2011, 06:48 PM   #14
Chris,
Curious why you are using the 5248 LUT rather than the CineStyle? Do you find it more accurate or pleasing? For me the CineSytle is on the verge of being too flat and the 5248 even more so. I'm just starting to play with this and trying to find what works best for me and would love to hear what you have found.
Thanks, Lloyd
Lloyd Coleman is offline   Reply With Quote
Old May 8th, 2011, 09:57 PM   #15
I think some people prefer their shot to be as flat as possible during filming so that all the information of the shot - shadow details, under and overexposed areas, color are retained. They can then, during post production, play around with the contrast or saturation level to achieve the look that they want.
Jimmy Toha is offline   Reply
