-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   Conversion help needed... (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/491656-conversion-help-needed.html)
Stephen J. Williams February 12th, 2011 03:08 PM
I'm not sure what I'm doing wrong. I followed so many videos on how to convert using streamclip not sure where the problem is.
First the problem: After conversion from raw to prores422 (plays back choppy on QT player, I assume the same for FCP).
Here's what I'm doing.
-Batch list
-export to qt
-apple pro res 422
-100% quality
-frame rate (i've added it on some and some I left blank.. doesnt seem to matter).
-unscaled
-export.
Thanks in advance
steve
Gabe Spangler February 12th, 2011 10:38 PM
Sounds like your computer might now have enough power to play files without glitching out a bit.
By the way, your source files are h.264, not RAW, but I understand what you mean.
Chris Westerstrom February 13th, 2011 04:33 AM
isn't prores a difficult format for quicktime to play up?
after transcoding to prores, from what I know it's best to transcode it back to either h.264 or some other presentable codec
Dave Pierpont February 13th, 2011 08:07 AM
Try apple pro res 422 (LT) that is still more than enough of a bitrate for t2i footy...That may allow for QT to handle it, if not then its your computer power...
Stephen J. Williams February 13th, 2011 09:25 AM
Hey guys,
Thanks for the responses. It's my computer power... My IMAC is getting pretty old and I'm super excited about my new one that should be here in about a week.
Turns out they play pretty well in FCP... I'm actually happy knowing that it's my hardware and not my workflow.
Thanks again.
Steve
