-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   Magic Lantern audio output update (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/491279-magic-lantern-audio-output-update.html)
Brian Tori February 5th, 2011 09:56 AM
Just installed the latest build onto my 550D. In addition to having control over audio gain as we all know, I now have the ability to monitor and adjust the audio via the mini USB output. Using the USB to RCA cable that comes with the camera and a simple RCA to miniplug adapter, I can now monitor the audio on my phones. This is fantastic. Thanks to those who work on this firmware.
Osmany Tellez March 4th, 2011 04:09 PM
Re: Magic Lantern audio output update
really????
how you do that?
I have the latest build...jan 14 on my t2i....i tried the usb cable but as soon as you plug it the LCD goes black...still don't hear the audio....but i will need to also see the screen...how you do it?
Steve Boutin March 4th, 2011 09:48 PM
Jan 14th? There has been at least 16 builds since Jan.14th. The latest is build March 3.
Magic Lantern 0.2.0 RC1 for 550D firmware 1.0.9 - Magic Lantern firmware development | Google Groups
click expand all, and scroll down page.
Brian Tori March 5th, 2011 09:14 AM
Hello,
Steve is right. Use the latest build before proceeding. To monitor the audio and have the LCD visible at the same time, make sure to plug the usb cable into the camera AFTER you power on the camera. If you do it before, the camera thinks you want to monitor externally and disables the LCD.
Osmany Tellez March 5th, 2011 11:18 AM
hehehehe...got it. wuao..they are busy...will install lates build..
thanks a lot guys
Gianni Paolella March 5th, 2011 03:01 PM
Hi,I downloaded and installed the last version,of the 3th Marxh, but I have not the crop image inside the screen and when I push the button the ML belove the screen disappear....only to me or is normal?
Gianni
Osmany Tellez March 6th, 2011 11:57 AM
before this update I had the cropmarks without a folder...i tried but they didn't show up...so i just droped the folder called cropmaks straight as it is in the cards and voaa..they work.
press..garbage button..to bring ML menu..look for cropmaks and press set to browse thru them...
one of the coolest new thing is...that it saves your configuration...wuao..it was a pain before..but now it comes back exactly how you left it,,,,cool.
Gianni Paolella March 6th, 2011 12:22 PM
Thanks, but the problem is that I have the cropmark, but when I push the botton the Magic Lantern menu that I have down on the screen disappear....and there is not any possibility to have again, so I installed the old version of ML 25th February, but I don't like this....Any suggest?
