Low ISO Noise with 7D
Hi,
I´m Felix from Germany and this is my first posting in this forum. Today I rented a EOS 7D to test DSLR filming. But I´m a little disappointed! The 7D produces a reasonable amount ofnoise in lowlight, even at 160 ISO I made a video, where I compare my Sony NX5 with the 7D in lowlight. http://www.steinhardtverlag.de/Felix/7D.mp4 As you can see for example on the white wall, there is alot of noise going on at low ISO levels! Blacks are ok, bright objects too, but between that I find the noise unacceptable for a lowkey Filmscene. Looks like cheap Video. Am I doing anything wrong with the settings or is this normal? Greetings Felix |
What lens is on the 7D?
24-70 mm 2.8
But the lens doesn´t affect noise, does it? |
What PP? Try the same shot on neutral with the contrast and sharpness turned down. That should make it alot better.
It was set to neutral. To all the settings that are recommended for filming. I googled a little
I just found a solution! I made a new clip of a white wall in lowlight and it looked awful! Like 16-color scheme in Windows 3.11^^ I converted the clip with Neoscene Cineform an cineform made a "10-bit correction for 5D and 7D Luma range and color space". Now the footage looks a lot (!) better (and brighter with more dynamic). Just grainy, without muddy noise like a VHS Camcorder. Pretty strange tough... Question is: Will this cineform filter work with the 60D, I might buy?....mmmmh |
Thing is, I wanted (!) this low light situation. I wouldn´t have used 1.4 for the shot because I wanted to test a low-key setting at low iso.
But now the problem is fixed! Damn Quicktime! |
The NX5 was set to 2.8.
But since Vegas got it all wrong, the files of the 7D are in fact 20% brighter now, when played with quicktime or converted with cineform and look great. So this comparison vid is complete nonesense. I would estimate ISO 320 is the same as -6 db at the NX5. So NX5 does a better job in lowlight <-> Noise but the 7D is very close! |
Awesome. So people should buy the NX5 instead of a 7D for working in low light. Wonder how the EX1(r) fares in that kind of comparison.
| All times are GMT -6. The time now is 10:12 PM. |
