-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   Mixing 24p and 30p footage on the same FCP timeline (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/478930-mixing-24p-30p-footage-same-fcp-timeline.html)
Michael Winget May 18th, 2010 04:14 PM
I brought a friend along to help me with a recent shoot, and made sure that our camera settings were identical. In my haste I forgot to make sure that we were both in 24p. As I watched the footage from the day's shoot, I noticed that his looked (or rather played) quite differently than mine. I checked his clip properties, and lo and behold he had shot the whole thing in 30p.
I've mixed different formats before in FCP, but never had to mix different frame rates on progressive video. I know there are a number of options here, but I'm looking for the one that has the least damaging effect on my footage. Do I convert the 30p stuff to 24p? If so, what app is best suited for the job? I know CinemaTools will slow it down (like it does with my 60p to 24p footage). I could just drop it directly onto the timeline, but the tests I've done with that method leave the 30p footage looking choppy.
What would you do in this situation?
Michael Dalton May 19th, 2010 07:18 AM
Hi Michael,
I know that horrible feeling, during the shoot of a series my camera somehow switch from 24p to 30fps, and I ended up with a half of episode on 24p and the other half in 59.98.
i tried many options to see the best result and found that converting the files was the best option. I used MPEG streamclip (free software) using BATCH, and it did a pretty good job on the conversions in a decent amount of time. Some clips are pretty stroby, but there is no way around them. If you started editing, simply overwrite the converted files you are working with. Assuming that you are working in Prores.
If anyone has a better solution, I'd love to hear it.
Good luck,
Michael D
Jeremy Pevar May 19th, 2010 08:50 AM
I just want to second Michael's suggestion. While it is technically possible to mix frame rates in an FCP timeline, it is not a good idea. Take the time and convert all the 30p footage to 24p (or vice-versa) before you begin editing. You won't regret it.
Michael Winget May 19th, 2010 01:15 PM
I've got MPEG Streamclip, and will try that. Any idea on which conversion (24p to 30p, or vice versa) will create the LEAST amount of strobing? I'd imagine going from 30 to 24, as you aren't creating frames that don't already exist (not that removing frames that do is any better).
I'll just give it a go and see what happens. Luckily the 30p stuff was the B-cam; I should be able to manage.
Thanks again!
Bill Pryor May 21st, 2010 03:17 PM
There is software out there you can buy that will do a better job. Magic Bullet and DVFilm come to mind. DVFilm - Digital to Film Transfers, Raylight Software for Desktop HD editing I've used them for video-to-35mm film transfer before but haven't used the software.
Michael Wisniewski May 21st, 2010 08:21 PM
When I've had to do this, I've converted both to 60i since there are common well-known and well-tested methods for 24p/30p in 60i. Then it's 60i all the way until the output/export to the delivery format.
