-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   7D Manual Audio control (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/475955-7d-manual-audio-control.html)
Wayne Avanson March 31st, 2010 10:08 AM
I was wondering if Canon might update the 7D firmware anytime soon to make the audio available with manual control like the 5D now does.
Anyone any thoughts/news/ideas?
Avey
Jon Fairhurst March 31st, 2010 12:28 PM
I have no idea about Canon. I expect that Magic Lantern will eventually be available for the 7D, but have no idea when. For now the juicedLink DN101 is one of the better solutions. It's not quite as clean as an H4n or DR-100, but it's more convenient in that there's no sync'ing.
Bill Pryor March 31st, 2010 01:22 PM
It took about a year and a half or more before they got it done for the 5DMKII.
Ethan Lane April 1st, 2010 01:54 AM
bit off topic but if I had to choose between the 5D & 7D right now I'd have a really hard time
Bruce S. Yarock April 1st, 2010 02:55 AM
I just got a Tascam DR-100, and like it. I also ordered a -25 db line (pinknoise) for going from the the Tascam to the 7D. Several of the news guys are using this cable, and I'm interested in seeing how usable the on camera audio will be, comming out of the Tascam.
Bruce yarock
Manus Sweeney April 1st, 2010 03:00 AM
for most purposes no matter how good the recorder/cabling it will still sound pretty nasty with the AGC unfortunately..
Philipp Sokolean April 1st, 2010 04:35 AM
Bruce yarock
How does syncing work with the Tascam DR-100? And why do you need -25 db line? I'm not an "audio" guy but I'm looking for a solution to finally use all my mics with the canon 7D...
Bruce S. Yarock April 1st, 2010 07:31 AM
Phillip,
in editing, you line up the audio from the Tascam so it's in sync with the audio on the 7d. It's pretty easy, especially if you have a slte, clap or announce the scence once everything is rolling.
The reason for the -25 db pad is that the line signal comming out of the Tascam is too hot for the Tascam. I tried without a pad and the sund was overloaded and distorted.
Bruce Yarock
Bill Pryor April 5th, 2010 01:40 PM
I got a cable with the pad also. Got mine from Videoguys. I have the Zoom H4N. It works fine. I only use it for recording ambient sound, like traffic noise, etc. The auto gain is OK for that kind of thing.
If anybody noticed, Juicedlink has a new gadget to be introduced at NAB. Not too long ago they came out with the add-on to the basic Juicedlink that sends a signal to the auto gain to trick it into dropping way down, then you boost gain manually with the Juicedlink. The new gadget is the same thing, basically, but all in one box. It has meters and a headphone jack. The only problem there is you would only have one channel and you're stuck with your audio going in through a mini jack, and my experience with those is that it's not a question of if it will fail, but when it will fail. I'm sticking with double system for awhile. If I had a gig where I'd need to shoot a lot of different interviews in a short period of time, then I might go for a single system approach with Juicedline. Like for a more run-n-gun documentary.
