-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   problem using Canon plug in for FCP / 550d (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/475326-problem-using-canon-plug-fcp-550d.html)
Mark Slocombe March 22nd, 2010 07:51 AM
Installed this new plug from Canon
Canon EOS 5D Mark II Digital SLR Camera
with no probs, using Nathan Beaman's hack to add 550d to list of cameras.
http://www.finalcutuser.com/?p=1829
All good - Log and Transfer in FCP 7.0.1 sees the files fine, I choose ProRes LT to transcode to in Prefs, as per Canon advice:
Canon Digital Learning Center - Introducing EOS Movie Plugin-E1 for Final Cut Pro
The import and transcode goes ok - then when I add the clips from Browser to Timeline / Viewer, I get black, no picture - tried changing alpha settings, no good. The clip's thumbnail in the timeline shows the content, and doublclick loads the clip in Viewer - but it plays only black>
Anyone else got this?
Mark Slocombe March 22nd, 2010 08:05 AM
Solved - nearly; I had missed (somehow!) changing clips' Alpha from None to Straight in Browser - that's made clips visible in timeline and viewer - but with orange render bar.
How to make Straight Alpha the default for the transcode?
Mark Slocombe March 22nd, 2010 10:23 AM
Fully solved - trashed FCP prefs and default Alpha is None/Ignore, but clips now play fine...
David St. Juskow March 22nd, 2010 11:12 PM
Had no idea about this. Timecode added? Sounds wonderful! Glad it's working for you!
