-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   Canon 7D Noise and Pixilation Issue - Please help (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/471776-canon-7d-noise-pixilation-issue-please-help.html)
Dan Neeson January 27th, 2010 10:15 AM
Hi Guys,
I was wondering if someone could help me...
I have a canon 7d and i just can't get any good low light pictures without a load of noise/ pixilation. I was wondering if you could please take a look at my settings/ videos and see if there is anything you can recommend?
Here are some videos where you can see noise on the left side of the subject's head.
YouTube - New Noise Video - desat - Canon 7d.
YouTube - New Noise Video - Canon 7d
(these were exported from AF CS3 as mp4 - so things are a bit blurred, but you can see what i mean from the next vid)
and you can really see it here:
YouTube - Canon 7d - noisy footage issue (desatured) (look at the above right of the subject's head - where the white fades to black... it's like a pixil ant party up there!)
Here are some stills that i extracted from other videos:
http://i974.photobucket.com/albums/a...non7DNoise.jpg
http://i974.photobucket.com/albums/a...oiseColour.jpg
Here are my settings:
Here is the set up I am using:
Canon 7d Body
Lens - Canon 50mm F1.8
Aperture: f1.8
Shutter Speed: 1/50
ISO: 200
24fps 1920x1080HD PAL
White Balance: 5000k (matched to light source)
Light Source 15w CFL Fluorescent lamp, (equivalent to about 60w - 75w incandescent) placed approx 1m away from subject's face.
Camera Settings:
User Def. 1
Sharpness = 0
Contrast = Absolute –
Saturation = 2 clicks negative
Color Tone = 0 (default)
Highlight Tone Priority = Enabled
ISO Expansion = Enabled
Converting footage from Canon format to Avid ADxHD codec using MpegStreamClip and editing in After Effects CS3.
All comments are very much appreciated
Thx :)
David Chapman January 27th, 2010 12:50 PM
I don't have experience with Avid formats, but I will say that I would need to see shots of the original to compare noise. The pixelation I see is from YouTube's h.264 compression for web and not related to what the camera shot. If you compress the footage enough with a low bit rate, you will see a lot of blockiness.
I also noticed that some of your uploads were a wrong aspect ratio.
Dan Neeson January 27th, 2010 06:26 PM
New Video Example
Thanks Dave,
Here is an uncompressed video that i uploaded straight from the flash card.
Any Thoughts?
YouTube - Uncompressed Video - Noise/ Pixilation Issue
Perrone Ford January 27th, 2010 07:09 PM
Yep....
Noise = insufficient light
Pixellation = weak h.264 codec in the 7D.
Shoot the same scene at ISO 640 and see what you get.
Daniel Browning January 27th, 2010 07:19 PM
One way to reduce noise is to let your highlights blow out by disabling HTP. Personally, I'd rather have the noise. :)
Perrone Ford January 27th, 2010 07:24 PM
Why? Reduce latitude in the shot and nothing needs to blow out.
Daniel Browning January 27th, 2010 07:32 PM
Because reducing latitude in the shot is not always possible or desired. For example, I don't normally carry a nuclear warhead bright enough to reduce the contrast in mountain landscapes. ;) Other times, I do have the nuke with me, but I just don't want to change the lighting because I like having highlights that are four (not three) stops above mid gray before clipping.
Perrone Ford January 27th, 2010 07:39 PM
I didn't mean in all situations.. I mean in THIS situation.
Ands sounds to me like you need to upgrade your arsenal to some include some smart, tactical nukes... Just to even things out a bit. Or you need a RED. :)
Daniel Browning January 27th, 2010 07:46 PM
I see now, thanks. Yes, he may want to do that.
Or both. That's how they made Book of Eli. :)
Dan Neeson January 28th, 2010 08:26 AM
Thanks everyone - i'll play around and see how it goes.
dn
