Canon PROTECT Filter for the EF 50mm f/1.2L USM Lens
I just got my EF 50mm f/1.2L USM Lens today, reading the manual, it says to install the Canon PROTECT filter to seal the lens for Dust, Humidity, etc., do I need to buy that specific filter ?, or I can use any standard UV filter installed, currently I have installed the SIGMA DG UV 72mm filter, maybe that's enough ?, please could you confirm, thanks a lot
Daniel, what type of filter would you advise if one really needed protection in front of the front element? We've been using UV's despite the ugly flares that pop up now and then.
Hi, just riding on this thread to ask a couple more questions, if you don't mind, since we're on the topic of filters.
I just bought Canon 7D and EF-S 17-55mm f2.8 (after hearing good reviews from here, and man, it is expensive in Singapore >.<). Pretty new in DSLR world and jumping into it in the hope of setting up a freelance event, wedding, corporate videography. So....I definitely need a UV filter to protect this glass. A man from a photography store recommended B+W UV filter to go with this lens, since apparently it's a great glass and one shouldn't stinge on filter to protect it. That cost S$200 (Singapore dollars), compared to Hoya HMC (S$45). He mentioned Hoya is a lower grade filter and there are bounds to be flares and more obvious distortion when using that compared to B+W. Well I'd really just like a filter primarily for protection, naturally without sacrificing much image quality (if any). Do you guys reckon there is a great difference between those two filters? Advantages vs disadvantages that you may know of? My heart tells me to go with Hoya ($45) - the cheaper option. Suggestions are greatly welcome :) |
Thanks for your reply, Daniel.
In your previous previous post, you mentioned you'd prefer Hoya HMC the most since it's easier to clean. I'm guessing you're not talking about the same Hoya HMC that you suggested I avoid? I went to the official Schneider optics (B+W) website and there's like a dozen UV filters available. I'd like to personally thank them for confusing newcomers into the DSLR world. Anyway, I noticed that the filters' mounts have either F-Pro and XS Pro on them. Do you know if either one is compatible with Canon 7D? As far as I understand it, only XS Pro has an additional front mount to attach lens cap or hood. Sorry for the multiple questions there. I'm an eager-to-learn newbie :) I'd be keen to get a UV filter soon and test out the difference between shooting with/without the filter, though. |
I am using the following F-Pro B+W filters:
50mm f/1.2L : B+W 72mm UVA (Ultra Violet) Haze MRC Filter #010 24-105mm f/4L : B+W 77mm UVA (Ultra Violet) Haze MRC Filter #010 50mm f/2.5 Macro : B+W 52mm UVA (Ultra Violet) Haze MRC Filter #010 They are working great and my understanding is that they are MULTI COATED. From B+W Web Site: CLEAR UV HAZE MRC (010M) "This UV Filter blocks the invisible UV component of light from the sky, which can cause blur and to which many color films react with a blue cast. These filters should be called UV-Blocking Filters, because there are filters for technical applications that pass UV radiation and block all the other wavelengths. Nevertheless, the short term “UV Filter” has become established among photographers. UV Filters are ideal for photography in high altitudes (in the mountains), by the sea and in regions with very clean air. The pictures gain brilliance and disturbing blue casts are avoided. Because the glass is colorless, color rendition is not altered, aside from the elimination of the unwanted blue cast, and no increase in exposure is required. That makes a UV Filter very suitable as protection of the front element of the taking lens against dust, flying sand, sea water spray and the like, and it can be kept on the lens at all times. It is recommended for analog color and black-and-white as well as digital photography. MRC (Multi-Resistant Coating) by B+W is not only an extraordinarily effective multiple layer coating, it is also harder than glass, so that it protects filters from scratches (for instance when cleaning the filters), and it is also water and dirt repellent, thus facilitating filter maintenance." It seems they are good for Digital SLR cameras as well. They have to be GOOD QUALITY filters, I paid around $100 for each one. |
Sorry for the confusion on our site. We are working hard to clarify our UV filter options. In short, the F-Pro mount is our basic filter mount and does not vignette on most lenses including your 17-55mm. The XS-Pro Digital filter is a slim mount ring that has front filter threads and should be used on full frame cameras like the 5D MKII or EOS MKIV with lenses wider than 18mm. Our B+W MRC coating is the original multi-coating on the market and is great for repelling water and dust. The MRC coating also features 99.8% light transmission. I hope that helps if you haven't already made a filter decision. Thanks, Ryan Avery Schneider Optics |
I do not have a Full Frame camera, I have the Canon EOS 7D (1.6 factor), and I have only full frame lenses, like the 24-105mm f/4L, 50mm f/1.2L and the 100mm f/2.8L Macro, can I still use the XS-Pro filters ?, thanks
XS-Pro filters will work fine for your camera and lenses but the F-Pro will meet your needs in this case.
I decided to purchase B+W 77mm UVA (Ultra Violet) Haze MRC #010 Filter - for both protection and daylight use. Daniel has a point - don't skimp on filters, especially on good lenses. Ryan, now I'm just hoping that I'm paying extra (with B+W filters) for quality, not just brand name :) |
I have seen multiple images from 5D MKII owners shooting at night using lower quality filters that have reflections from the front element surface being imaged on the backside of the filter. I sold these users MRC coated filters in all cases and they no longer have the issue.
If your use requires a filter, then you are right that you should buy good quality glass that matches your lens and coatings. I'm sure you will be happy with your purchase. Ryan Avery Schneider Optics |
