Have you seen this flickering in your video?
I bought 7D for 2 months and bought it to Japan for vacation. But I don't know why the video would look flickering when I zoomed out. It happens even when I use M mode; everything is knocked. The video below shows this flickering at the beginning when I zoomed out wide of the Japanese robot.
YouTube - Test 7D.wmv |
What lens do you have on the camera. Is it one that varies in aperture?
The lens I used was the Canon kit lens EF-S 15-85 mm 3.5 - 5.6 IS USM.
This flickering is not a closing of aperature but alternating darkening and brightening of the video as can be seen in the video. |
1. Variable aperature lens 2. Camera set to automatic exposure mode trying to compensate for the lens. |
The camera was set to M mode, which should knock both the aperture and shutter speed down. Moreover, shooting upward to the face and then facing the sun at the background do not lead to closing of the aperture further. After seeing the face of the robot, the zoom was already at the widest possible point.
Auto ISO? It will do this in Full Manual if enabled.
I'm not an expert on these (Still) lenses, however what I think your seeing is that even though you have the camera set to Manual, the Iris is still stopping down because you do not have a, for a lack of the proper technical term, "constant" speed lens. It's not an f/2.8 throughout the entire zoom range..
So if your using the kit lens it is f/3.5 at one end and f/5.6 at the other, so your seeing the change. Just a thought... |
I think Chuck is right. If you set your F-Stop to f/3.5 and you're fully wide on the lens, it's going to try to keep the lens as open as it can while you zoom in. On the Kit lens the more you zoom in the more it get stopped down. So when you're at 85mm it's going to be at f/5.6, when you zoom out it's going to open up again. The only work around for this problem on this lens is to just set it to f/5.6 when you do a zoom like that to avoid the issue.
Best way to test this is to do a quick zoom in and out on manual with the aperture at 3.5f and see if you get that flicker. The set the aperture at 5.6f and see if you get the same results. Auto ISO is another thing to check.
Another way to test this is to set your f-stop where you want it, press the DOF preview button, which opens the iris to that f-stop and at the same time twist the lens about 1/4 of a turn, as though your removing it. This disengages the auto functions on the lens.
With ISO set to AUTO, and the camera in Manual mode the exposure is NOT "locked". You will see brightness changes occur from anything that affects exposure. Zooming is one thing and panning from one area of brightness to another will cause brightness changes.
These brightness changes are not instantaneous either and that explains the "flickering" effect seen in this segment. The cure is twofold. As suggested above manually set the aperture at the widest opening available on the telephoto end so the camera is not trying to react to what is senses as a physical aperture change. The other thing to do is press the ISO button on top and a "table" appears with all of the ISO values. If AUTO is selected move the cursor bar to the ISO value that appears on the lower right (I don't have my 7D in front of me) when you partially depress the shutter release. Setting a specific ISO value in Manual mode will "lock" exposure and you won't see the camera trying to adjust to lighting changes. Hope this helps. |
Wow thank you guys for all the suggestions. I'll try what you all suggested and see if I can 'lock' the supposingly 'Manual' mode further.
The camera is on Manual, its the lens that's causing the issue. With a constant aperature zoom lens, this same shot would've been fine.
Yes it's the lens. And even if you set the aperture to f5.6 at the widest position, you will still get flicker when you zoom. I don't know why, but I experienced the same thing with several lenses here. The only way to use the zoom on the canon DSLRs is with aperture-fixed lenses, like the 18-55 f2.8, 70-200 f.2.8, etc.
With the kit lens, you must use it like a prime. Frame your shot, record, stop record, reframe your shot, record. |
I experience the same problem as Jean-Philippe Archibald does. I locked everything, including using M mode, fixed ISO, and closed the aperature to 5.6, and found that the flickering occurred when I zoomed in or out.
I also twisted the lens about 1/4 of a turn to disengage the auto functions on the lens as Chuck Spaulding mentioned, the flickering disappeared. Turning back the lens into the fully engaged position, the flickering appeared again when zoomed in or out. And I could see darkening of the picture when I zoomed in as the aperture was down from 3.5 to 5.6. The flickering did not happen when I used a fixed focal length lens. It seems like it is related to the communication between the lens and the body. |
David,
What video format were you shooting at, and at what shutter speed? I had the same issue as yours last time (although mine was constant flickering), when my setting was at 720p 24fps, and my shutter speed was at 1/100. I switched it to 1/50 and it seems to fix the problem. Some people in the forum have mentioned that it's best to set the shutter speed at two times the value of your frame rate - 24fps at 1/50, 25fps at 1/50, 30fps at 1/60 and so on, although i'm still not very clear about its relationship. |
Jimmy,
The video format is MOV. as specified by the camera. The shutter speed does not affect the chance of appearance of flickering. It happens only when I start the zooming and ends when I stop zooming. It happens outdoor and indoor. The video does NOT darken in M mode even when the lens was facing the sun or when I moved from indoor to outdoor. But it immediately flickers once I turn the zoom ring. |
Hi David, the fact that it didn't shift your exposure when you disengaged the communication between the lens and camera demonstrates that it shifts because this lens is not a continuous aperture lens. [sorry if that isn't the right term]. It has a range of f/4 to f5.6 for example.
If the the camera is allowed to communicate with that lens it will always shift its aperture to correspond to the correct focal length even with everything set to manual exposure. There are two ways to correct this, first use this lens with it rotated slightly so there is no communication with the camera body, everything will be manual. Second use a lens that has a constant aperture. Other than that I think that everything is working as it should, there really isn't anything to fix. I hope this helps. |
