Brand new 7D and Low Battery message after 2 days on 50 shots
I just got my 7D this Monday, been playing around and taking some pictures (around 50), the battery was around 75% yesterday noon, and sudenly yesterday night I tried to use the camera and got the message of an almost dead battery and the camera refused to turn on.
I removed the battery, then plugged it back again and battery was at 75% and everything was normal again. Any previous experience with this weir behavoir ?, does it means something wrong with the Camera, Battery or something else ? I am concern that might be something wrong with the camera body ?, suggestions and comments please, thanks |
Seeing as you're in MN, were you outside, and how cold was the camera/battery? Brand new batteries usually do need a few cycles before they reach their full-capacity, but the cold doesn't help.
The likelihood that there's something wrong with the camera are slim. Not to say that it can't happen..
Id recommend getting another battery and make sure there's not something out of sorts with your settings that might have kept the camera on. Is this the battery that came with the camera and did you charge it before using it? |
Yes, it's the original battery that came with the camera
My camera body bricked on me within 7 days. Why it's always important to buy it from a reputable business.
What do you mean by Bricked ?, what happened ?, thanks
I have 4 batteries and nothing like this has happened to me.
I also have 6 Canon batteries cycled over 100 times and have never had this problem.
However from my limited knowledge of batteries, I would cycle the battery once by drawing it down to maybe 20 to 25% remaining charge, let it cool down and then recharge. My guess is that there is nothing wrong with the camera, battery or connections. There may have been a surface charge on the battery that caused a rapid drop in voltage. |
I agree with Jay.
"Bricked," his camera was broken therefore it turned into a Brick. Kind of like getting a DUI and turning your car into a paperweight... |
Every time I put in a card it said 'must be formatted' so I tried in the computer, inside the camera and the same error msg came up. Called Canon and said that I'd have to return it. |
Summary, after testing multiple batteries, all of them full charged, I kept getting the same problem, so I went to Best Buy and exchange the Camera for a Brand New one, it's an older S/N, I hope the problem will be solved with this one, testing it right now.
| All times are GMT -6. The time now is 12:45 PM. |
