-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   Two monitors simultaneously - is it possible? (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/469395-two-monitors-simultaneously-possible.html)
Heiko Saele December 13th, 2009 07:39 PM
I'm going to rent a 7D next weekend, and we would really like to have two monitors - one on the cam for me, the other for the director, the choreographer (there will be a lot of dancing) and maybe someone who watches continuity.
Is it possible to use both the AV out and the HDMI out at the same time?
Robert Kennedy December 13th, 2009 08:02 PM
doubt it
Haven't tried it but I doubt it would work.
I have been looking into a HDMI splitter in order to take the signal from the camera and split it, one goes to an on-camera monitor (either Manhattan LCD, Marshall, or smallHD), the other goes to a large 24" for others to watch the footage on.
HDMI splitters I am considering are by Gefen/GefenTV.
-R
David Chapman December 13th, 2009 08:20 PM
This has been discussed before, but I think you can go from the 7D > MXO2 Mini and out to another HDMI and component source. You need a Macbook Pro in the connection as well for the host.
HDMI and Analog I/O for Mac and PC - Matrox MXO2 Mini
Keith Moreau December 13th, 2009 08:24 PM
There are a lot of HDMI splitters out there that should work well. Get an active one that has electronics in them, not just a splitter cable. The Gefen ones, as most of Gefen's products are premium priced for pros. There are a lot of cheaper ones that are technically fine as well, in the $50 range.
Joe Lawry December 14th, 2009 12:51 AM
Blackmagic Design HDMI to HDSDI converter.
You get 2 HDSDI outputs.
Christopher Drews December 14th, 2009 01:09 AM
What Joe said...
Most pro monitors are SDI / Component HD only.
Plus you get long cable runs on BNC without the fear of bending / breaking HDMI pins.
Charles P. also has a way to run these mini-adapters off of anton battery packs.
-C
Joe Lawry December 14th, 2009 01:12 AM
I plan on powering mine with an aftermarket Swit EX1 battery (have an ex1 also).
Take the D tap out of the battery and just make a cable to go to the converter.
You definitely do not want to be running long HDMI cables, so having the converter right by the camera is a must.
Will rig this up sometime in the new year.. Waiting on my Z Finder to arrive and some more invoices to be paid so more toys can be acquired.
