-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   Timelapse with After Effects (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/469329-timelapse-after-effects.html)
Dave Timperley December 12th, 2009 02:08 AM
I've noticed a few posts about timelapse suddenly.
My preferred program for processing timelapse is Adobe After Effects.
I import a sequence of frames and drop them onto a time line.
Then I turn on frame-blending to smooth out the motion.
Sometimes a clip looks better if I stretch it x2 or x3.
AE also allows panning and zooming within the sequence of frames.
Some examples I've created with After Effects...
YouTube - Autumn timelapse 09: City (part two)
YouTube - Autumn timelapse 09: Storms (part one)
YouTube - Vivid festival Light walk time-lapse: Sydney 09
AE will also suck in a sequence of RAW files ;-)
Amos Rafaeli December 13th, 2009 02:34 AM
Timelapse
Hi
They are very nice.
Did you had any flicker problem? and if so how did you solve it?
Amos
Chuck Spaulding December 13th, 2009 04:01 AM
Regarding the flicker, check this out: Timescapes - Digital Timelapse Discussion View topic - Flicker
Jon Fairhurst December 13th, 2009 02:58 PM
That's a good discussion.
The simple answer for avoiding flicker is to use manual mode. If you are using a small aperture, hold the DOF button and untwist the lens to keep the aperture fixed. Best practice includes covering the eyepiece for long exposures.
Other good ideas are to use Live View (it drains the battery quicker, but holds up the mirror) and to use the "silent shooting" mode to cut the shutter cycling in half.
Dave Timperley December 13th, 2009 03:52 PM
Yep, as has been stated. Manual mode is the go.
If you need to use auto anything like for sunsets, turn off auto white balance before anything else.
I've had more trouble with the WB then the auto exposure controls.
If you capture in RAW you don't need WB anyway.
Jon Fairhurst December 13th, 2009 10:02 PM
Another trick for sunsets it to bracket your shots with different exposures. Save the frames as three different timelapses. Stack them on three timelines and blend as desired.
This is where a small program to sort the images would be helpful. Manually moving every third image would be monotonous!
Paul Cronin December 15th, 2009 08:40 AM
Looking at adding a 7d to my kit and have a question with the timelaps. Sorry if this has been answered already but I could not find it.
Is there a selection in the menu that lets you choose, example "1 frame per sec"? How do you set the timing of each picture?
Jerry Porter December 15th, 2009 04:25 PM
You need a remote timer to make it work. Do a search for Canon timelapse remote timers you will come up with several options.
Paul Cronin December 15th, 2009 04:35 PM
Thanks Jerry that is very helpful.
Keith Moreau December 15th, 2009 06:53 PM
Jon, do you have such a Mac app or script to do this? I do bracket a lot but wind up doing HDRs, however on occasion I do have need to move the groups to separate folders for processing. If not I can probably create an applescript to do this.
Jon Fairhurst December 15th, 2009 08:25 PM
No. I run a PC and don't have software for this. It wouldn't be hard to code though...
Chuck Spaulding December 16th, 2009 11:22 AM
Keith what application do you use to create your HDR's?
Keith Moreau December 16th, 2009 03:04 PM
Chuck,
I use Photomatix from HDR photo software & plugin for Lightroom, Aperture & Photoshop - Tone Mapping, Exposure Fusion & HDR Imaging for photography. It's some of the best software you can get that does batch processing of sets of HDRs. It has quirks and I'd like it to use more processors on my 8-core to do it's thing more quickly but I find the support from the company to be stellar. I also use Photoshop CS4 sometimes for HDRs but it's a bit arcane / too simple sometimes. I might also process the resultant HDRs in Adobe After Effects, there are some plugins that fine-tune timelapse type images.
It can take a while to process 18MP images from the 7D, previously I was using lower res cameras for HDRs.
BTW Photomatix works on both Macs and Windows.
One thing to be careful of with using the 7D for timelapse is that you can eventually wear out the shutter on the camera, there is a limited life on those things, so don't just do timelapse willy-nilly or you soon reach your shutter's end of life, and I don't know how much it is to repair a 7D. Also you want to lock the mirror up so that part doesn't wear out either. If you're doing a lot of long timelapses you might want to do it with a still camera that doesn't have a mechanical shutter, I have a bunch of older Nikons Coolpix along with some excellent timelapse controllers from Harbortronic that if I leave them in the wild and they get stolen or destroyed it's not like I'm out $2500.
Paul Cronin December 16th, 2009 03:24 PM
Interesting point Keith the shutter will ware out. Not good since I am looking at a 7d for a lot of long timelaps.
Keith Moreau December 16th, 2009 03:33 PM
Yeah, Paul, another thing is HD = a pretty low MP (megapixel) count, like about 2-2.5MP, so you can do HD timelapses with a pretty modest digital camera, as long as it has either a remote interface that a timelapse controller can use or built in timelapse (though this is pretty rare). To do HDRs you'll it's beneficial to have very wide 'brackets' on the 2 or 3 exposures you blend together for each frame. The 7D has some of the widest bracketing (+3, 0, -3EV) of any camera, which is excellent for HDRS.
Unless you want to do pan and scan within a timelapse and need the 18MP image, go with smaller res to avoid long processing times for your NLE or other post processing of the stills.
Jon Fairhurst December 16th, 2009 03:38 PM
On the 5D2 I recommend this approach: (Probably works with other Canon cameras as well.)
* Turn down the LCD brightness to help battery life.
* Put the camera in "silent shooting" mode. This cuts the shutter cycles in half.
* Put the camera in "Stills Only" Live View mode. This allows long exposures.
* Cover the eyepiece to limit stray light.
* If using a small aperture (high f-stop), press the DOF button and untwist the lens. This reduces flicker.
* Set everything to manual, again, to limit flicker.
* For sunrises and sunsets, bracket the exposure time. Put every third photo on a different timeline and mix to taste.
* Shoot RAW Large if you have a large CF card, powerful computer, and lots of time. Otherwise get everything set well up front (WB, exposure, picture style) and shoot JPEGs.
That's it! You'll get no rolling shutter and no aliasing - just beautiful images. :)
Paul Cronin December 16th, 2009 03:39 PM
Keith I shoot HD timelaps. My reason for the 7d is not the video but the 18MP stills for timelaps with pans, zooms, and other movements. The video would just be a bonus.
Sounds like I should go for another still camera that shoots without a mechanical shutter. Can you recommend a 18MP + camera for this?
Jon Fairhurst December 16th, 2009 05:04 PM
Micro 4/3 cameras have no mirror, but I believe that they still have mechanical shutters. RED cameras have no mechanical shutter, but the 5K wide sensor cams aren't out yet and will cost more than a 1D4 with many shutter replacements.
I'd say that a DSLR is the way to go, but you have to budget for shutter replacements.
Daniel Epstein December 16th, 2009 06:33 PM
There are a lot of things which go into Timelapse with a Digital Still camera which can guide your choice. Battery power or external power become critical if you are planning long periods of shooting. The quality of the manual controls (iris, shutter speed,gain, manual focus) and interval settings make a huge difference. It is really great if you can judge the quality of the exposures while the shot is happening. I can't say whether the 7D fits the bill but the mechanical shutter or lack thereof is not high on my list of worries when it comes to Timelapse.
Check out this link to see some Timelapse I have on Vimeo
Keith Moreau December 16th, 2009 06:50 PM
Sorry Paul, I can't recommend an 18MP without a mechanical shutter, though they may exist. Probably for you, I would just investigate what a shutter costs to replace and budget for that. I think the 7D is one of the best DSLRs for high quality timelapse, and I've made about 10 timelapses with it so far. However my snap count is probably in the 20,000 range or more because of it, so it's something that I know, if I use it extensively, may be an issue. I mean 10 timelapses is not that many, and I've probably used up 10% of my shutter life doing them (in 2 months of use). I use the camera primarily for video but I like the option of being able to do some high quality timelapses with it, partly out of curiousity too to see how well they would come out (very nice.)
And Daniel- very nice timelapses and the other purchase-decision variables you mention are also important.
I have some cases I've made with medium-sized lead-acid 12v batteries (motorcycle batteries), and have selected digital still cameras that are compatible with that voltage, so this is also a consideration, especially for multi-day timelapses.
If you have done timelapses with the 7D or another DSLR with a mechanical shutter, how many snaps have you done on a camera or have you ever had a shutter go out?
Paul Cronin December 17th, 2009 08:40 AM
Daniel thanks for posting. Were all of those done with DSLR? Nice to see Woodshole bridge I have family there. Too bad Vimeo is such a low bit rate the footage seems cloudy.
I have done a hundred or more timelaps with my XDCAM cameras and have always had stunning results. But no options for pan, tilt, and zoom. These would be the only reasons for me to use a DSLR for timelaps. For video well maybe a few clips but the upper XDCAM line footage is beyond stunning and fits my business very well, besides my high end clients demand it for their broadcast.
Keith thanks for your warning on shutter life. So 200,000 clicks and a replacement is needed? Just an estimate but nice to know it is in that range. Is shutter replacement 1/2 the price of the camera body?
I am sure there are nice options on battery life problem.
Not a lot of experience with DSLR. My close friend (Onne van der Wal) who I do a lot work with is a top end Canon sponsored shooter so he always takes care of my still work. I am just looking at adding a DSLR to my kit for timelaps and maybe some short clips. So it is nice to have a access to all this info and help me choose the right piece of kit. Much appreciated.
Does anyone here have both the 5dMII and the 7d and use both for timelaps?
Daniel Epstein December 17th, 2009 09:24 PM
Hey Paul and Keith,
In answer to various questions.
Paul,
Some of the shots were done with the Nikon 5400 and some with the Nikon D70S. The DSLR can do many more frames per minute reliably than the 5400 plus the DSLR battery life was much better. Can't tell what happens with compression etc but it is a miracle it looks something like the original at all. Gamma and pedestal are from a Mac and that may be part of it.
Keith,
I haven't worn out the shutter on my d70s yet but it is getting close to 80,000. The funny thing is I don't like to shoot too many frames on any particular shot since they rarely are on screen for very long. I don't usually shoot subjects that take longer than an hour and often use longer intervals between shots so I can play with exposure lengths. I do feel the camera can wear out as part of the process so it is somewhat expendable
Keith Moreau December 18th, 2009 01:53 PM
I think the 7D is rated for 150,000 clicks. I've never replaced a shutter before, and I think info about 7D shutter replacement is not easily found. I did a google search and found these links:
Flickr: Discussing Shutter Life and Timelapses in Canon DSLR User Group
Re: 10D typical used price & shutter: Canon EOS 7D / 50D - 10D Forum: Digital Photography Review
Seems like it's in the $250 to $500 range. Probably a call to Canon service would tell you. If you get an answer let me know.
So regarding the quantity of snaps for timelapses, if you do the math to convert to video at 30FPS, 20 seconds (the minimum clip length to work with in my opinion) is 600 total shutter releases. If you like to bracket the shots, and I like to have a bracket of 3 shots, -3ev, 0ev, and +ev, then you multiply that by 3, so you now have 1800 snaps. If you're like me and you want to be able to control the speed of the timelapse, either for ramping or just to slow down the timelapse in your NLE, the you might want to use shorter intervals, having the choice to 'throw away' frames if you want. Then a typical shoot for 20 seconds of video could easily be 3600 snaps. So if the typical timelapse session is 3600 snaps, the you have about 41 timelapse sessions before you might need to replace the shutter. Depending on your schedule this could realistically happen in a couple of months.
So, it's just a choice to make.
I think the criteria are:
Is there a wired remote shutter release interface for an intervalometer?
Are there enough pixels to accomplish the pan and zoom tasks?
Is there an electronic shutter version that meets the requirements?
Good luck and post back with any findings!
Paul Cronin December 18th, 2009 02:09 PM
Thanks Keith,
Well I am going for a 7d from a friend who has used it for a instructional DVD. So very lightly used and a nice deal.
I found the same info of 150,000.
One thing that I find different in my math is when I shoot timelaps on my EX cameras I use 1 frame per second. So at 30fps time line that is 600 frames for a 20 second timelaps. Why do you shoot three times the frames using a bracket of three shots?
As for your three questions:
I don't know on the remote shutter release since this is new to me.
Yes I think there are enough pixels to accomplish pans, tilts, and zooms. You don't need much to have a huge effect. And at full res raw it gives nice room at 1080p and even more if I shoot slow-motions on my XDCAM for the timeline since that is 720p.
I think this third question is moot now since I am going for the 7d.
I will come back and I am sure have questions on timelaps with the camera. I will be glad to post my findings here and on my Tech Talk page on my site when I ever have time to update it.
Thanks for your help and talk again soon.
And Dave thanks for starting this thread and getting me off my but to add a DSLR to my kit.
Liam Hall December 18th, 2009 03:13 PM
Some people do 3 or 5 frame bracketed exposures so they can create HDR (High Dynamic Range) sequences. Personally, I rarely go longer longer than six seconds of capture (in PAL land 150 frames).
Paul Cronin December 18th, 2009 03:23 PM
That makes sense Liam thank you for the response.
Daniel Epstein December 18th, 2009 07:51 PM
I also agree with Liam about number of frames. I have done plenty of shots with 150 frames and fewer. It depends on the subject of course and how long you think it needs to be on screen. The reason to shoot longer amounts may be the transition the subject is going through but very little ends up being as long as five seconds continously onscreen. I don't bracket the exposures but that doesn't mean it isn't a good idea
Paul Cronin December 19th, 2009 09:37 AM
Thanks Daniel,
It is rare I run a finished timelaps longer then 10 sec.
What is the remote timer controller of choice? Canon or other brands?
Pick up the 7d today and a new 2/3" camera next week so busy holiday testing new gear. Lots of ducks needed to organize.
Daniel Epstein December 19th, 2009 10:32 AM
Paul,
Well I hope you have fun with your new gear. As far as controllers go I don't know what is out there now as every time I buy a new camera I do new research to see what it needs. Not sure if the Canon has an internal timer to use but they do sell an external model Canon TC-80N3 Timer Remote Control which should get you started. Street price around $140
Paul Cronin December 19th, 2009 11:04 AM
Daniel,
Thanks that was the one I found. Looks like it only goes down to 1 sec then lots of options above that time. Should work. I will see what else is on the market to make sure I don't miss something new that offers more options.
Have you used the Canon Controller?
By the way I will start testing my PMW-350 next week. Abel shocked me yesterday saying it will be in early next week. I thought I would have been waiting till mid Jan. Nice to have dial in time since it will go to work mid Jan.
Daniel Epstein December 19th, 2009 12:29 PM
Paul,
I haven't used the Canon controller but I remember that most camera controllers end up with a 1 second minimum when doing timed intervals. You can look for other controllers to see if they can do any better. There are computers an software which appear to control the camera but you may not want to deal with that.
Good luck with the 350. It is nice to hear Sony didn't wait until New Years Eve to start delivering them.
Paul Cronin December 19th, 2009 02:49 PM
Thanks Daniel it looks like I will go with the Canon controller.
Dror Levi December 26th, 2009 08:53 PM
Sorry but I am kinda confused still.
So let me ask you that.
If I wanted to make time-laps of clouds, how many sec between shots?
Regis Hervagault December 26th, 2009 11:40 PM
like all things timelapse, one setting might not be so good out of context... it depends a lot on the speed of the winds.
judging the right interval is a skill that comes from past experiences so don't wait any longer and go out there shooting.
i suggest keeping a diary on what settings were used for each shot and review your results. you'll soon get a feel for the right values to dial in just by looking at the scene for a few minutes
Michael Nistler December 27th, 2009 01:51 AM
Hi all,
For my Canon 7D I went with the Canon knockoff, manufactured by LinkDelight. It's called the Apurture Timer Remote Controller AP-TR3C. I found mine on ebay for around $40 but see it's available for less than $30 direct from LinkDelight:
LCD Timer Remote AP-TR3C for Canon TC-80N3 7D
It works fine for time-lapse, with a maximum of 99 events (snapshots) before restarting. My only gripe is the $3.00 battery (2032) only lasts a few months after it is plugged into the timer. Fortunately, the battery power connection swivels into place so I don't let the battery make a connection until the day I'm going to do time lapse shooting.
It's lightweight and average ruggedness for a small portable unit. But at $30, it's hard to go wrong for the price. Some may find the instructions aren't great, but with 15 minutes of fiddling it's easy enough to figure out what's going on by searching the net. Functionally, it works about the same as this bigger Apurture model (but won't do 399 intervals):
YouTube - Digital Timer Remote First View and Test by Linkdelight.com
Regards, Michael
Daniel Epstein December 27th, 2009 09:21 AM
Hey Dror,
Regis is correct that you should experiment if you can over how fast you want the clouds to move. If you start with a couple of seconds between frames it will only take you a few minutes to get enough frames to see how the motion is working. You can also change the speed in post so shooting extra frames doesn't hurt too much. If you start making long intervals between frames then you have to wait much longer to get a few seconds of footage. I have been using between 3 to 10 seconds for most of my material but specific shots may be better with different intervals.
