shutter speed vs. aperture
during bright daylight shooting in photo and video mode, what are benefits of using ND filter for shallow DOF photography vs. achieving correct exposure by increasing the shutter speed to match a wide open aperature?
i'm newish to the DSLR thing and still trying to understand. Also, when shooting video with different lenses, how can i make sure the footage has even exposure and DOF across both lenses without a lightmeter and exposure chart? Thanks. |
In movies if you use too fast a shutter speed the image strobes quite irritatingly. Rule is to use a shutter speed double the frame rate (ie 1/60th second at 30fps).
Steve |
right... Try recording running water and go from 1/60 gradually up to 1/1000, you'll see why you wanna keep it low.
For example, if you have these lenses: EF 50mm f/1.8 EF 70-200mm f/4L EF 28-135mm f/3.5-5.6 The maximum aperture value of the slowest lens will be f/5.6 at the full telephoto end of the EF 28-135mm lens. Therefore you'll want to manually set an aperture value of f/5.6 or slower no matter which of these three lenses you're using. |
That will work for depth of field but not exposure Chris. These are f/stops not t/stops. The light transmission will vary between lenses at the same f/stop. Zoom lenses in particular will vary greatly compared with primes and you could quite easily find yourself missing exposure by a stop, which on a digital camera could be crucial.
I suggest the OP learns the histogram and how to use it. That will tell him exactly what is going on. |
Liam, I noticed this a few weeks ago when I got the 50mm f/1.4. I took a photo with that lens at 2.8 and then another photo with my 17-55mm f/2.8 (trying to match focal length) and the 50mm appeared to be a stop brighter (at least a half) at the same aperture setting.
The histogram and exposure readings in the camera should help produce a good exposure for each photo/video. Any other details can be adjusted in post. |
The depth of field depends on several factors including aperture, the focal length of the lens & the distance of the subject. Keeping a constant aperture while changing to a lens of a different focal length will not maintain the same DOF. See here for an interactive calculator Online Depth of Field Calculator
Yes of course, but in PAL land 1/2 shutter would be 1/50th as you'd be shooting 25P.
Steve |
cool. thanks for all the help guys
| All times are GMT -6. The time now is 01:31 AM. |
