Slow motion scaled up and given pulldown?
Just throwing this out there:
1. If I wanted to shoot slow motion, I could shoot in 720p 60fps, and then interpret that footage in Premiere as 30p to see a clip at twice the duration and appears slow motion. How would that look scaled up to 1080 30p in amongst footage shot natively at that resolution? 2. How about if I shot in 720p 60fps, and wanted to get to 24fps 1080p? I have no idea how I would interpret the footage in a 24fps project. |
You can take 720p60p into cinematools, conform to 24p, put into 1080p24p timeline, and it will play in slow motion. If you then want to turn the footage into normal speed 24p, you will have to time-confirm to the original 60p run length in Compressor.
Is there a workflow for PC based users? It appears that CinemaTools is a Mac platform product.
you can do it in Adobe After Effects or Premier Pro for the PC or MAC
You can do it in Edius and Sony Vegas too. In Edius you just set the frame rate you want it to play at. In Vegas you need to stretch the clip but if you do it accurately and also disable Resample there will be no artifacting.
To convert the clip to 24p, Mathew mentions something called "time-confirm" using Compressor. I'm not sure what that means, but on a PC, after getting the clip to play at 24p on the timeline as above, you just need to render the timeline to whatever target format you want. If you use a low loss codec such as Cineform or Canopus HQ the results should be very good. Richard |
I will do a test and post the video. It'll be interesting to see the difference between it being slowed down to 30p and 24p. I imagine 30p will look a bit smoother since that will be exactly 50% of the original speed.
Well it will be smoother simply due to the fact that it has more frames per second. If the slomo is done properly there will be no artifacts due to frame blending or resampling.
Richard |
As I recall, in Vegas, I believe you would simply apply a change to the play back rate on the clip, from the time line. So instead of play back at 60p, you would change the rate to get you 24 fps. This can be done by right clicking on the clip while on the time line, and entering properties. If I recall right, and there will be a play back rate. I think you would set the playback rate at .400.
Can any 7D/Vegas user confirm that process in Vegas ? Note: You will end up with only a partial of the clip left on the time line, but that clip can be expanded to the end at the same playback rate. |
When you bring a video clip into your editor the program reads the metatags to determine the frame rate. I would recommend going in and changing those metatags to your target frame rate instead of running it through extra steps in your editing system. Your editor will see the video as 24p (or whatever you set the rate to) and play it accordingly with no rendering or quality hit.
You can find free programs that allow for metatag editing. I can give a brief explanation of anyone is interested. It only takes seconds and doesn't change the video itself at all. Only how your software plays it. |
Richard |
Richard |
On second thoughts I'm not so sure that Procoder/Express would work. The files I have converted in Procoder the past were 5D2 at 30fps and I didn't need to change the frame rate. Procoder will adjust the clip frame rate rather than resample if the difference between source and target rates is small (e.g. 25p to 24p). But 60p to 24p is probably going to force a resample which is not as good as interpreting the clip frame rate.
I could test it out if you like, but not until the weekend because I am tied up with work until then. Richard |
i would think that if you want to slow down 60p footage to 30p, you would want to shoot at 1/125th shutter to get less motion blur. I could be wrong with all this as the digital stuff boggles me sometimes. some people have shot at 1/1000th shutter with the 5D2 and it didnt look too different from say 1/200th shutter
I tried converting 60p to 24p with Procoder, but it doesn't produce a slomo effect at all, it just resamples the frame rate and makes a 24p clip of the same duration (and speed) as the 60p original.
There is a setting that allows you to Enable Source Playback Speed Adjustment and set Max Adjustment to x%. I tried setting x to 500, but it still would not stretch the clip on conversion. Streching works fine when I convert 25p to 24p, but it looks like 60p is too far away for the design intentionm of this feature. So it looks like you would need to use the NLE for the conversion to slomo. Richard |
| All times are GMT -6. The time now is 03:50 PM. |
