-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   DVinfo 5D Mark II vs 7D for HD Skinny (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/390810-dvinfo-5d-mark-ii-vs-7d-hd-skinny.html)
Jenn Kramer September 12th, 2009 02:56 PM
We've posted a first pass at a 5D vs 7D for HD shooters article:
5D Mark II vs 7D for HD DV Info Net
It's going to be an evolving document as we get more information and actually get to compare the 5D and 7D side by side.
Comments, suggestions and friendly criticism? Post it here!
Greg Boston September 12th, 2009 04:27 PM
Nice little write-up, Jenn! Sounds like the 7D will be a worthy piece of hardware at a great price point.
-gb-
Jon Fairhurst September 12th, 2009 05:55 PM
Hi Jenn,
One small error is that you list the 5D2 audio as 12-bits. It's 16-bits.
To make sure I'm not blowing smoke, I double checked the audio in a 5D2 MOV file in Sound Forge 9. It's definitely a 16-bit structure. I also double checked the datasheet for the AK4646 audio chip used in the camera. It has a 16-bit A/D. My noise analysis indicates a 16-bit system. Canon's official specs and manual say nothing about the bit depth.
I'm not sure where the 12-bit rumor popped up first. I hadn't seen it before the 7D announcement. I think that somebody heard that the audio in the 7D was better, recalled that the sample rate is indeed faster, and then took liberty with the bit depth.
Anyway, nice summary of the differences between the cams. The big wins for the 7D are the frame rate and cost. The wins for the 5D are sensor size and Magic Lantern (audio, zebras, e-rack focus). The day that Magic Lantern is ported to the 7D, and 24/25p is available on the 5D2 (I'm still optimistic), it will be a pure sensor size/cost trade off.
The biggest bummer about the 7D isn't the lack of wide lenses, it's the lack of fast wide lenses. The 24/1.4L and 28/1.8 are pretty much the limit. There is wider EF-S f/2.8 glass, but you always have to wonder how usable those super wides are when all the way open.
Jenn Kramer September 12th, 2009 05:59 PM
Good catch, Jon, I'll update the article vis-a-vis 12/16 bit. I think that may just have come up because of the 44.1k/48k difference.
Bill Pryor September 12th, 2009 07:45 PM
The article said you can only record a single audio track...does that mean only one channel or two channels on one track? In other words, can you record one channel at one level, the other at a lower or higher level, assuming you have a Beachtek?
Jenn Kramer September 12th, 2009 07:48 PM
I believe that with a mixer you could record two mono signals, one to the left channel and one to the right channel, but the camera would do AGC on both. I mainly put that in to contrast with the old DV camera ability of recording a single 12 bit stereo track and then recording another 12 bit stereo track to the same video. I should probably clarify. Updates momentarily.
Bill Koehler September 12th, 2009 08:50 PM
"Due to EU tax regulations the cameras are limited to 30 minutes of shooting in their SD modes, which equates to a 2 gig quicktime h264 file. At HD bitrates this results in a 12 minute shot."
You might make it clear that at HD bitrates it also becomes a 4 GB QuickTime H.264 file.
I just double checked against Page 157 of the Owner's Manual.
Jenn Kramer September 12th, 2009 08:54 PM
Ah ha, that would indeed be 4 gig. Updated!
Bill Pryor September 13th, 2009 09:24 AM
Looks to me that until when/if Magic Lantern is ready, it might be better to just do double system sound. Although, I've noticed that Beachtek has a box for the 5DMKII (presumably OK for the 7D as well, I'd think) that does what ML does in this regard, to defeat the auto gain. Still, auto gain makes me nervous.
Chris Barcellos September 13th, 2009 10:12 AM
Magic Lantern in the 5D today does more than the Beachtek. Magic Lantern gives you control of gain levels in order to set sound properly for your particular input device. The Beachtek, as I understand it, lowers the level by introduction of an inaudible signal that "fakes" the camera out. You don't need a $ 350.00 adapter for that. I have done the same with an MP3 player and my old Beachtek. In fact with an MP3 player you can get a bit more control by adjusting volume of the inaudicale signal in. The Beachtek still has significant noise associated with the level it puts the camera at.
Shawn Wright October 20th, 2009 05:31 AM
Great article.
So any idea on the timing of Magic Lantern for 7D?
Jenn Kramer October 20th, 2009 04:35 PM
The firmware has only been out for a few days, and I'd imagine there are fairly significant architectural changes between the software for the 5D and the 7D. I wouldn't plan on it being released super-soon.
Jim Froom October 23rd, 2009 02:57 PM
I just read your review and wouldn't raise a fuss over anything you said.
I own a 5D MK ii and & 7D (for 23 days), as well as the GH1. I packed the 7D this AM to return it to the dealers and then this afternoon, took it out and started a new test shooting with the GH1 and 7D.
My sole reason for taking back the camera was even though I'd tested for the heating problem being reported on the 7D, I had recorded for over 1 hr and 20 minutes without seeing the heat indicator. It was done a few weeks ago so don't remember the specifics, but my best recollection is I was on 30 fps and mostly stock settings.
Last weekend during a shoot with all 3 camera, on the 7D shooting with custom picture settings at 30 FPS, I got the heat indicator at 44 minutes or so and then again during the 2nd hour.
It's just another gotcha when shooting. I'm conflicted as to keep it or not.
Since you did a direct comparison, I'd say in the overheating department, the 5D MK ii is the winner.
Jenn Kramer October 23rd, 2009 03:04 PM
Jim, that's a good point, I'll add a section about the overheating issues.
Mauritius Seeger November 5th, 2009 08:20 PM
i would have thought the limit is simply due to the max file size limit in the fat32 file system.
Mauritius Seeger November 5th, 2009 08:28 PM
"on the 5D, since it’s a full frame camera, all lens mm equivelents are true, so a 28-135mm lens is a reasonably wide to intermediate telephoto. On the 7D this same lens (the kit lens, incidentally) becomes a 45-216mm, not very wide but longer on the telephoto end."
this is a bit misleading: the lens is still a 28-135mm. but used on the 7D the field of view is equivalent to a 45-216mm lens on the 5D.
Cole Seidl January 17th, 2010 11:43 AM
Thank you very much for this. I've been pulling my hair out trying to decide which is for me, and even to just discover the full specs of each of the cameras.
Tony Davies-Patrick January 22nd, 2010 06:18 AM
Nothing to do with fat32. It is just due to the big difference in import taxation costs between stills and video cameras to EU countries. Crazy but true.
