-   Canon EOS Crop Sensor for HD (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/)
-   -   Article from Canon (https://www.dvinfo.net/forum/canon-eos-crop-sensor-hd/387990-article-canon.html)
Bill Pryor September 11th, 2009 09:14 PM
Article from Canon
I hadn't seen this article before.
http://www.usa.canon.com/dlc/control...articleID=3050
It appears you can use the shutter button for auto focus, just as you do in still photography, by holding it down halfway, letting the camera focus, then releasing. Very handy for a quick focus shift.
Khoi Pham September 11th, 2009 10:57 PM
We have to wait and see how well it works, the manual recommend not to use it because aperture might change during recording, I don't think they improved any over the 5D focus for video but I hope that I'm wrong cuz I don't mind pressing the shutter for instant focus with any focus point I choose. (-:
Dave Blackhurst September 11th, 2009 11:05 PM
And it has the ability to take stills simultaneously... hmmm, this camera is really starting to sound interesting...
Xavier Plagaro September 12th, 2009 01:30 AM
The video is stopped for a couple of seconds when you take a picture! I wonder if it starts a new file or you can have a video clip with a "hole" due to the picture...
Martyn Hull September 12th, 2009 01:53 AM
[Very] its probly been told but i am unsure how muc video an 8GB flash card will hold, 12 mins continual i believe but what total.
Bill Koehler September 12th, 2009 05:56 AM
The data rate is ~12+ mins into 4 GB for a data rate of ~40 Mbps. The limitation isn't the flash card capacity. The limitation is the maximum file size that either the FAT16 or FAT32 filesystem will support. So you can have a very large capacity flash card with multiple 4 GB clips on it.
Chris Hurd September 12th, 2009 07:55 AM
It works exactly the same as the 5D Mk. II. It does not start a new file; it simply records a freeze-frame for 1 sec.
Xavier Plagaro September 13th, 2009 04:17 AM
Thanks Chris, that is an important piece of info! ;-D
