Trivial C100 Mii Question
It seems almost shameful to ask: How do I toggle between the two custom displays that you can set up in the displays menu? The manual only goes into how to set up the options, but not how to switch between 1 or 2. After two years with this camera I never really worried about this, but now I have an external monitor it may be a useful option.
Re: Trivial C100 Mii Question
Terrance, I thought the short description on page 122 was how to toggle between the two. You're saying that's only for the set-up menu? That action itself doesn't switch between the two presets?
Hi Chris,
I went back and took another look. Then it dawned on me: Cust. Disp. 1/2 are not separate display versions that you toggle between; Cust. Disp. 2 is simply a continued list of options from Cust. Disp. 1. They are different lists. I utterly misunderstood what was going on, but then if things are working how I want I leave well alone. My hope had been to have a minimal version that I would toggle on for the monitor. No biggy. Know thy camera I guess. Thanks, Terence |
| All times are GMT -6. The time now is 09:44 AM. |
