canon c100 mk II clog output problem
Hello, if anyone can help would really help me out... my canon c100 mk II is set to shoot clog and records it fine on the card in camera, however, it does not record clog to external device (ninja blade) the blade has been checked and exchanged and we ran a test from hdmi to television and indeed it is not flat colour at that output... is there something I am overlooking in the camera set up? anyone who can offer any feedback much appreciated... thanks Boris
Re: canon c100 mk II clog output problem
Hmm...I have a C100 MKI and the Blade and mine outputs C-Log out of the HDMI to the Blade fine. Perhaps there is an HDMI output setting in the C100 MKII that is not on the C100 MKI? Are you sure you are not looking at the Blade screen with the C-Log compensation or HDR on? I didn't think the C100 has the processing power to send different PPs/resolutions to different outputs like the C300 MKII has?
Thanks Dan,
I looked at HDMI settings, and tried turning off the LUT and it has sorted the problem...probably obvious to many... thanks for the advice Boris |
