Video: Upgraded Canon Log2 and New Canon Log3
Jon Carr and Canon released a video today showing the new "upgraded" Canon Log2 and Log3 in the newest version firmware.
C-Log2 looks much improved in it's shadow noise. Log3 seems like a modest upgrade to the original C-Log, with less saturation in near clipped highlights and perhaps a little cleaner color in the shadow. New firmware should be released tomorrow. |
Re: Video: Upgraded Canon Log2 and New Canon Log3
Thanks for that Barry.
Having fried my c300 doing a firmware upgrade a year ago I might pluck up courage and install the new C300mk2 Firmware although I'm pretty happy with Canon Log. |
The new firmware v.1.0.4.1 is now available via the CanonUSA website.
https://www.usa.canon.com/internet/p...B0AMD0F1Q42K25 (I think I'm going to set up a DR/Color test in the studio to compare before and after. While the noise reduction in the shadows of cLog2 looks pretty good, canon was generally proud of how much detail they were holding in the deepest shadows with CLog2, so I'm curious how much, if any, of that detail we'll be losing, plus any color changes that might have happened in the interim.) |
Matt Porwoll has a pretty extensive look at C-log 3: Matt Porwoll | Cinematography » Canon C300 MKII: First Look at the new Canon Log 3 Gamma
I upgraded to the new firmware, shooting a before and after test in the studio with my homemade ghetto xyla chart.
Not much in the way of surprises. Clog2 sees a modest reduction in noise at 800 iso, and is very usable at up to 3200 I think. Clog3 adds a stop of DR in the highlights, and the color in the highlights looks cleaner. The net effect for someone shooting Clog3 "to the right" is a much more open mid and shadow range, greater tone separation below 20 IRE, compared to the original Clog, something that I always was yearning for from that gamma. This could be my new favorite setting, although CLog2 is certainly much more useful than it was before. As far as the noise reduction in Clog2, there doesn't seem to be much penalty. I see no loss in details. There is a drop in luma noise, which slightly unmasks the chroma noise that was already there. The highlight smearing is reduced, but not eliminated. It's still visible in the darkest chip of the chart, but has disappeared further up the scale, which is exactly what you'd hope for. I'd say, good job Canon. But I always say that :-) |
Thanks Barry for the review, sounds good to me.
I'm also looking forward to checking this particular 'new' feature: "Enables magnification to be used even during recording." Finally! Glad that Canon is listening to its customers. I thought it might a technical limitation, but apparently not. Now for some slow mo frame rates in 4K and we'll all be happy..... As I have two Canon C300 Mk2s, I am planning on installing this firmware only on one for now, to do a comparison, especially of Clog2. |
Canon also fixed the issue where switching frame rates (i.e. 23.98 and 29.97) would have the camera reset the resolution. So if I had been shooting 29.97 1080 at one job and I switched to 23.98 for another, the camera previously reset the resolution to UHD. Now it stays at 1080.
I have a list of issues Canon still needs to address, such as S&Q toggling via a body button, a fixed shutter angle (that drives me absolutely bonkers), DPAF functionality in VFR modes 60fps and under, Face Detect+Follow DPAF (so when the talent turns their head and Face Detect switches into DPAF mode, the targeting reticle is now where Face Detect was last used instead of where you last moved the DPAF target box), and Normal Recording (crop) mode to eke out just a bit more zoom for telephoto moments when you aren't using slow motion. As for 4Kp60, if that happens, it will be by the end of the year, and if you don't see it by year's end, I don't think it will ever happen. Also, keep in mind that the ability to do 4Kp60 means the bandwidth is there to do 1080/2K in 120 without the crop. So It seems highly unlikely in my opinion. |
Yeah the frame rate reset thing has gotten me more than once, so happy to see it fixed.
As for the 4kp60 one, when you look through the image pipeline white paper, the image is processed at this rate until it is downsampled and compressed. So on the processing side, the bandwidth is there The bottleneck seems to be in the compression stage, which, to me, sounds like a typical Canon move. They feel 4kp60 needs more than 515 mbps or whatever the max is for the codec currently. And then, of course there is that camera they are supposed to unveil at IBC. |
However, it's not simply a codec thing because, again, if the bandwidth is there on the front end, then there's no need for a crop mode. If you get 4Kp60 working on this camera then crop mode is no longer needed. And the bitrate in crop mode is the same as the bitrate normally, so it's the upfront processing that makes crop mode necessary, which means it's the bandwidth from the sensor to the encoder (because otherwise the sensor could be fully scanned at 120fps for 1080 120 instead of cutting out a 1080 piece of it). |
2 Attachment(s)
So...again this info is from the C300 II white papers...the maximum bit rate in XF-AVC for the camera is 550 in 120 frame HD or 2k mode (vs 410 for 4kp30).
When you look at section 6.0 of the image performance enhancements white paper, it gives a workflow for the 1080p60 YUV 4:2:2 (figure 3). If you read the whole document, it becomes clear that the YUV workflow is essentially processing the image at 4kp60 (balloon showing RGB 8mpix frames) followed by downsampling to HD or 2k. The pipeline is identical to the one used when it's processing 4kp30, the only difference is in the 4k mode it's doing it at 30 frames and then skips the downsampling step prior to compression. (figure 5). So the camera is fully capable of processing the image all the way to the point of compression at 4kp60 in 10bit 4:2:2 YUV. It really seems like a compression (encoding) or "write-to card" issue, which, I think was why initially Mitch at Convergent Designs stated that they should be able to record 4kp60 to the odyssey recorders (until he got his hand slapped by Canon and retracted the statement). I really had hoped that we'd get an upgrade for this...but given that they didn't do it with this most recent firmware bump, I think we're looking at a feature that will differentiate the c500 replacement. |
I think that's fine and dandy, but then that still does not explain why there is a crop mode for 1080/2K 120 at 10-bit 422. If what you say is true, then why is there a crop mode at all? The bandwidth is the same, and picking between downsampling and a crop is something done right at the front of the image processing chain.
There's a section in that white paper that talks about the 120 fps mode. I think it's more than "the same" bandwidth.
---"the data rate of the video components emanating from the image sensor system must be constrained so that the processing and recording can retain a high integrity." If we look at how it's processing the 2kp60 image in full frame, it's processing it at 4kp60 and then downsampling to 2k/HD. Given this scheme, full frame, 120fps 2K/HD would need to be processed at 4kp120 and then down sampled. So the actual processing bandwidth would need to double, or they would need to debayer in a completely different way for this. Now sure...sony's done it, although their process seems to add about the same amount of aliasing as canon's does....I don't think either of them look that great. I believe the C500 dropped some vertical resolution to get it's higher frame rates. ...but I'll bet that new camera coming out next month.... |
2 Attachment(s)
But...that's where I got it from... |
Yes, it's completely wrong. It's actually a bit less of a bitrate in S&F mode (the grayed out codec selection shows 110Mbps instead of 160Mbps). I had 93 minutes left of recording on my CFast card at 10-bit 422 160Mbps Intra 1920x1080 Normal Recorder. When I set it to S&F Crop mode at 120 fps, that record time went up to 136 minutes.
Regarding the 120FPS Bit Rate:
When you look at 120FPS footage in XF Utility, it says the footage is at 110Mbps variable. But it is important to remember how we are shooting 120P in this system. We are not just shooting 120P and playing back 120P, we are in Slow and Fast Motion where we have chosen a "base" or playback frame rate to encode at. So the bit rate we are seeing is the "playback" bit rate of sorts. It's not really for the 120 frames per second, but instead for the 24 or 30 of those 120 frames we have chosen to playback in that second. Then consider that speed in which it's captured is 5 times that amount if shooting 24P (since 120 fps is five times the speed of 24 fps), and that is what gives the 550Mbps rating. |
Great explanation Loren, Thank you. Makes total sense.
