-   Canon Cinema EOS Camera Systems (https://www.dvinfo.net/forum/canon-cinema-eos-camera-systems/)
-   -   C100 strobing (https://www.dvinfo.net/forum/canon-cinema-eos-camera-systems/526527-c100-strobing.html)
Kathy Smith January 21st, 2015 05:31 AM
C100 strobing
Hi,
I am trying to figure out how to avoid strobing effect with my C100. Or maybe it's called flickering. I use 24p frame rate. If I'm following someone for example, or panning how do I make the flickering go away. I probably need a higher frame rate?
Darren Levine January 21st, 2015 07:08 AM
Re: C100 strobing
Faster frame rate is the only way to mitigate strobing, which is just a basic affect of movement on lower fps/higher movement.
check this out Panning Best Practices
Daniel Epstein January 21st, 2015 07:58 AM
Re: C100 strobing
Darren's link is very useful. Strobing is definitely a part of the 24 frame experience. There is a reason TV went to 30 frames a second even though we all love the film look. What shutter rate are you using? The faster it is the more stutter you will see. I have a producer who wants motion on as many shots as possible so we use 29.97 for her projects as she likes fast moves which strobe too much at 24. The way you shoot also makes a difference. Panning seems to create more issues than moving forward or back. Also some displays have more trouble with 24 frame rate than others so you may be seeing a playback issue as well.
Kathy Smith January 21st, 2015 08:58 AM
Re: C100 strobing
This is very helpful but it only talks about panning, I am experiencing this when turning the camera using glidecam for example. I suppose that would do the same thing
Gary Huff January 21st, 2015 03:18 PM
Re: C100 strobing
It's exactly the same even if the move looks a little difference. This applies to all motion.
Kevin Lewis January 21st, 2015 05:45 PM
Re: C100 strobing
Kathy, I too shoot with the C100. I typically use a shutter speed of 48 and never have an issue. You may see some strobing on the Lcd or your playback monitor, but do you actually see it in your final rendered video?
Kathy Smith January 22nd, 2015 04:16 AM
Re: C100 strobing
yes, I see it on the actual video. I will make a clip to show later today
Kathy Smith February 3rd, 2015 03:38 PM
Re: C100 strobing
OK, I just did a test. Here is the resulting video. I am seeing some kind of flickering when or I don't know what to describe it, it's the most pronounced when looking at the etches of things. Am I moving the camera a too fast?
Kevin Lewis February 3rd, 2015 04:10 PM
Re: C100 strobing
You are not panning to fast. To me it looks like you are using incorrect render settings or perhaps shooting 24pf and not handling it properly in post.
Kathy Smith February 3rd, 2015 05:10 PM
Re: C100 strobing
Kevin,
What render settings should I be using? These are the settings I always use. I am importing this to FCXP. I am pretty sure I'm shooting 24p, but I'll double check tomorrow.
Gary Huff February 3rd, 2015 05:25 PM
Re: C100 strobing
If she was shooting PF24, there'd be interlaced lines.
Kathy, what is your shutter speed? 180 degrees or 1/48 if you are shooting 24p?
Frankly, to me it looks like you're moving the camera too fast.
Kevin Lewis February 3rd, 2015 09:35 PM
Re: C100 strobing
The first time I watched in SD now that I re-watched in HD, it looks much better. Make sure that if you are shooting 24p that your shutter is set to 48. When you export, make sure that you are not exporting as anything other than 24p. If you are shooting PF24, make sure that your NLE is not picking it up as interlaced footage. It also looks like you are using the auto focus. If you are, make sure you try re-shooting with it off. Its hard to gauge properly with things going in and out of focus. When I shoot 24p with my c100 panning to quickly is not an issue. I don't change the way I pan just because i'm shooting 24p. Now that being said, you cant go whipping the camera around but you should certainly be able to follow a moving object without an issue provided that you are using the correct shutter speed. You can also try resetting your camera to the factory defaults in case you inadvertantly changed a setting.
Gary Huff February 3rd, 2015 10:11 PM
Re: C100 strobing
Actually, just set it to 180 degrees. You can do that on the C100 and it ensures that your shutter speed is always correct no matter the frame rate. Only change it for those instances with lighting that strobes in the frame.
Unless you are shooting 30p or 60i. Just make sure your export matches your footage.
Neve, ever, ever shoot PF24.
If that's the case, then judder simply doesn't bother you. You should always adjust the speed of your camera moves depending on your frame rate (60i can handle a lot, then 30p, and 24p is dead last). For proper 24p panning, the rule of thumb is that it should take 7 seconds to pan an entire frame's worth of information (so anything on one edge of the frame should take 7 seconds in your pan to reach the other side). Doing it faster than that causes judder, and you either live with it, pan slower, or use a faster frame rate.
Jon Fairhurst February 3rd, 2015 11:56 PM
Re: C100 strobing
That's awesome, Gary, I just responded to you in another thread and quoted the 7 second guideline, then I read your post here quoting the same. :)
For completeness for the other readers, when whip panning or tracking a subject, one can go faster. It's those pans on static backgrounds that really show the judder. Of course, very fast whip pans will show skew due to rolling shutter, but that's another topic.
FWIW, I did a pan of almost exactly 7 seconds across a building recently and I still noticed the judder. One reason is that I accelerated at the start and decelerated at the end, meaning that the speed mid-pan would have been a bit too high. But also, it's not like judder occurs at 8 seconds and is invisible at 6. It's more of a soft threshold. There's still judder at 6 seconds, but most audience members won't notice it. Once you know to look for it, you can't not notice it...
Gary Huff February 4th, 2015 07:43 AM
Re: C100 strobing
Most people simply won't notice, so I wouldn't sweat judder too much, just something to be aware of.
For the best example of this that I have seen recently, check out the graveyard scene in The Good, The Bad, and the Ugly when Tuco is running through it. He is running full tilt, the camera is locked on him and panning with him, and the background becomes this crazy ugly blur, almost like something out of 2001.
Kathy Smith February 4th, 2015 09:30 AM
Re: C100 strobing
Ok, I just double checked. I shoot everything 24p, 180 degree angle. So I just need to pan slower. I notice this utter less when a person is walking and the camera is following. It's way more visible for me on scenes that the focus is not on another moving object.
Gary Huff February 4th, 2015 11:48 AM
Re: C100 strobing
Yeah, if you look for it you will see it, but provided you shoot in a way that the eye is drawn to your subject, it becomes less noticeable to the average viewer.
Kathy Smith February 4th, 2015 04:51 PM
Re: C100 strobing
I don't know why but strangely I never notice it on any slider shots.
Gary Huff February 4th, 2015 05:27 PM
Re: C100 strobing
Most slider shoots look a little goofy if they move too fast.
Kathy Smith February 4th, 2015 05:55 PM
Re: C100 strobing
Yeah, and that's probably why I am unconsciously sliding slower and so there is no jutter.
