Mounting two wireless receivers on C300?
Has anyone found a good solution to mount two wireless receivers on a C300 and still have good access to the camera's handle?
Thanks. Thierry |
Re: Mounting two wireless receivers on C300?
Handheld: breakout cable to waistpack with 2 receivers.
Tripod: Rails with Battery plate with wireless plate attached. Kind of like the arrangement on a regular broadcast shoulder cam. Depends on the wireless kit used. The Sennheiser series are small enough to mount but I find my older Lectrosonics need to be off camera if I am handheld. |
5 Attachment(s)
I only have one mounted. But the best solution I found was to get a right angle at the hardware store and mount it on against the BNC jacks (since I never use those), but attached to the side using 3m dual lock. I also have a couple velcro spots on top of the BNC jack covers otherwise it will lever off the dual lock connection when bumped. There's still enough room to get my hand around the handle.
I don't think it would work stacking two receivers, but in case it's useful to someone else I attached photos. |
2 Attachment(s)
Looks pretty nice and compact for one wireless. Here is what I rigged this morning. Not perfect but not bad either. At least, the camera is fairly well balanced and the wirelesses don't interfere with the camera handle.
The best solution by far is a dual-channel receiver like this one from Lectro:
SR Series | Receivers | Wireless & IFB | Products It can be fitted with a sleeve which has a hot shoe mount (still an issue with the handle though) and a battery pack which will last days. This is what I have been using since I got my 300, and love the setup. |
You can also attach 1 receiver to the C300 grip strap.
Derek, I agree completely that this is the best way to go if you can. I have used the Lectro SR series arrangement on occasion with a soundman I work with and it is the best. Works with a variety of small (and big) cameras when you need to be mobile and handheld.
1 Attachment(s)
I'll let the photo speak for me...
5 Attachment(s)
I think I found another solution to mount two wireless receivers. I have a run-n-gun gig coming up and need to use the top hot shoe for a monitor. I wanted to keep the receivers out of the way, so I bought a handful of parts from CoolLCD.com and put them together to sling the cold shoe mounts under the handle. The three zip ties make it surprisingly solid, definitely not going anywhere. I think the "final product" will have black zip ties. It cost me about $20 in parts, but the result seems to be pretty good without anything hanging off the camera at odd angles. Finished rig shown in the final photo. I'm satisfied.
Nate looks clean but how do you pick up the camera by the handle now? I guess you don't.
Just around the front part of the entire handle. Not ideal but worth it to have the mics where I want them.
I used this on my 60d
http://www.bhphotovideo.com/c/product/685141-REG/J_Rod_THE_J_CUBE_The_J_Cube_Accessory_Shoe.html Use it now on my c100 It's pricey, but very robust. And unlike most 'double' shoe adapters , it's height is very low. |
I am currently reviewing several Wooden Camera handles and rigs. I'll let you guys know if any will work for mounting Wireless units
