25p vs 50i ( progressive vs interlaced )
So this is a bit of an old chestnut and obviously a subjective issue.
I watched the trailer for Philip Johnson's new C300 primer and was struck by a statement he made advising against recording in progressive mode. ' Every so often I get a phone call from somebody starting down the HD route and the first questions what do I use? Is it 50i, 50p, 24, 25, you know, basically as far as I'm concerned you stay away from 24 or 25p unless you are working with a director who is looking for that particular look ' Since I've been working with DSLR's and more recently with full HD cameras such as the XF305 and very recently the C300 I've always recorded, edited, transcoded and uploaded in progressive mode. The reason for this is that my work is predominantly delivered for viewing on computer and HD LCD screens which have progressive displays. Were one to record interlaced, the finished piece would need to be de-interlaced prior to delivery or upload to sites such as Vimeo. So all my filming is done at either 1080 or 720, with a frame rate of 25p. Is it all about aesthetics? The look? Does one method produce higher quality frames? |
Re: 25p vs 50i ( progressive vs interlaced )
Otherwise, stay progressive all the way. Sporting events, or broadcasting will benefit from interlaced. But that's about it. Downrezzing, uploading for web, and viewing on monitors is all progressive by nature. |
I suspect what he is referring to is the rendition of motion, and 24/25p can be very uncomfortable if you try to (say) pan too quickly. (It "stutters".)
But interlace at 50 fields per second and 50p give similar motion rendition, so you can still be "progressive" AND have smooth motion - it's just that with most cameras it's only at 720, 720p/50. I can't see any reason to shoot 720p at 25 fps. If you want 25fps, go for 1080p/25. If 720 is adequate resolution, why not go for 720p/50? |
Normally for the same frame size, progressive will be have higher spacial resolution than interlace. To prevent aliasing the fields are created by using pairs of lines, so the upper field is created from lines 1+2, 3+4, 5+6 etc then the lower field uses 2+3, 4+5, 6+7 and so on. This line blending reduces the resolution slightly.
The only things I shoot in interlace are the air shows I shoot for an external client. Everything else I have done in the past 4 years has been progressive. Progressive is so much easier to work with in these days of LCD displays. Unless you have a proper external CRT monitor in the edit suite then, you'll never know if your field order is correct or not. How many people have HD CRT's? |
Progressive. Progressive, progressive, progressive. This is the year 2012 after all.
[/sarcasm] |
A camera op might like interlace, but no one who does effects and compositing in post ever will! :)
I don't really understand why anyone would choose to shoot interlace unless it involves some very fast action these days. |
Even if it is fast action, you'd be better off shooting in 1080 50/60P with a different camera. Or even 720 50/60P with the C300. Interlaced introduces all kinds of problems and once you go to interlaced you can never do anything else with it without losing vertical resolution. 50/60P allows you the most flexibility.
I shot my first film on my C300 at Gatwick Airport in interlace, it looks awful on a monitor with the fields clearly visible, never again.
Progressive every time. Hope you're enjoying the camera Mark. |
Yes Claire - I'm delighted with the camera.
I'm in Andalucia for a week and decided to bring the camera with me. It's really easy to work with the bright light here through juggling ND, aperture and ISO. I'm still needing to look at the camera body to make changes but think that after a few more days I will be able to find things whilst keeping my eye on the viewfinder. |
