-   BlackMagic Design HyperDeck Shuttle (https://www.dvinfo.net/forum/blackmagic-design-hyperdeck-shuttle/)
-   -   Recording F3 422SLOG to Hyperdeck Problems (https://www.dvinfo.net/forum/blackmagic-design-hyperdeck-shuttle/515097-recording-f3-422slog-hyperdeck-problems.html)
Matthias Sachal March 17th, 2013 08:10 AM
Hi Guys, Im having a problem recording SLOG422 to my Hyperdeck2 at all. And on top of that not having the option of using my external EVF on my F3. What am I doing wrong?
I updated my F3 to Version 1.4 which should enable me to use SLOG with at least 422.
-Turning on 1.5G Ypbpr422 & Video (which is seemingly the only option with the V1.4 update), does not change the look of the Material at all.
-The gamma curves and picture profiles are not turned off as I expected
-It also disables me to simultaneously use the HDMI port, even though im only using one of the Dual Link SDI ports.
So, what I want is:
-Have HDMI Port on and my SDI Port running on SLOG422 with 1 BNC Cable
-Have my Display Options (Sound Levels etc.) on my HDMI VF
-Not have my Display Options burned into the SDI Signal
Is that somehow possible? Or am I stuck with just YUV422 If I need to use my HDMI Port?
Dennis Hingsberg April 12th, 2013 09:37 PM
Re: Recording F3 422SLOG to Hyperdeck Problems
slog is accessible only via creating a custom picture profile.
press the custom profile button on the back of your F3 under neath the viewfinder and create a new profile. Call it slog for fun, then go into the settings and under GAMMA select SLOG instead of REC709.
You might also want to turn the matrix and detail to OFF. That is a closer representation of what the original PAID RGB upgrade slog offered in terms of look.
Matthias Sachal June 8th, 2013 04:59 AM
Done. THX Dennis
