-   BlackMagic Design HyperDeck Shuttle (https://www.dvinfo.net/forum/blackmagic-design-hyperdeck-shuttle/)
-   -   Anyone use hyper deck as converter? (https://www.dvinfo.net/forum/blackmagic-design-hyperdeck-shuttle/508629-anyone-use-hyper-deck-converter.html)
Thomas Wong June 19th, 2012 02:45 PM
I am thinking to buy hdmi to sdi converter. And I look and price and specific this, only $50 more and it has recorder function.
I want to connect fs100 hdmi to hyperdeck, then hdmi out to monitor and sdi output feed to atem tv studio.
Will this work?
Frank Glencairn June 20th, 2012 03:41 PM
Re: Anyone use hyper deck as converter?
Works, I do it all the time.
Think of it as a great converter, that comes with a free uncompressed recorder ;-)
Frank
Thomas Wong June 20th, 2012 04:52 PM
Thx frank
One more thing, is it has to be SSD drive? I want to record a concert. It's gonna cost a oit if I have to use ssd
Shaun Roemich June 20th, 2012 07:12 PM
Thomas: a couple of things...
Yes, the drive NEEDS to be SSD.
By the time the video gets to your ATS, you are going to be VERY delayed, especially coming out of an FS100 which had some of the longest lag I have ever seen coming out of any output, digital or analog. The video is delayed at least 2 frames, based on my experience. Add another for hdmi to HD-sdi, and another for the frame store sync at the ATS.
Thomas Wong June 20th, 2012 07:16 PM
Hi Shaun,
do you mean the hyperdeck will have more delay than a normal hdmi-sdi converter?
Shaun Roemich June 20th, 2012 07:21 PM
1 frame, same as any. Just a poor signal path choice if audio sync is important or if delay to a screen is important.
Thomas Wong June 20th, 2012 07:25 PM
do you mean hyperdeck is 1 frame more delay than the normal converter?
coz i have a BM hdmi-sdi converter for sony fs100, now i need to buy another converter for canon xf100. I am looking into the hyperdeck because it's just $50 more than the converter.
if they are both 1 frame delay, i can just shift the audio from post
Shaun Roemich June 20th, 2012 07:36 PM
No ADDITIONAL delay but I don't think your cameras are going to be in sync. Again, the FS100 is the worst camera I have ever worked with in terms of how long it takes to get a signal out of it. The Canon is likely to be faster by several frames.
Lee Mullen November 27th, 2012 03:36 AM
Is thie method easy to set up? How would you do it to record from HDMI out?
