Inquiry About Blackmagic Design URSA
Regarding URSA, I have two inquiries:
1- How much does the body weigh? 2- Is the mount interchangeable? If I purchase EF Mount, is it possible to remove it and replace it with PL Mount for PL lenses compatibility and vice versa? |
Re: Inquiry About Blackmagic Design URSA
Any reply....
According to the BM Ursa page
https://www.blackmagicdesign.com/pro...blackmagicursa you can change the mount but each mount includes the sensor - I don't think it would be cheap! The specs http://www.bhphotovideo.com/c/product/1044785-REG/blackmagic_design_cinecamursa4k_ef_ursa_4k_digital_cinema.html say it's 16.5 pounds |
It is really awful to find the body so heavy, while other companies and parties compete to reduce weight in order to impress customers and make life easier for shooters!
When you get right down to it, the Ursa weighs about as much as the most popular cinema cameras currently on the market, which is Arri's Alexa line.
The reason behind this stability could be the overall physical design of the camera and the appropriate location of centre of mass. Cinematography cameras have been designed with stability and balancing issues taken into consideration, whereas DSLR cameras are intended for photography primarily and video shooting capability is nothing more than being an additional and helpful feature.
If I were to purchase URSA, what would be the best choices for support rigs and matte boxes ?
Any reply ??....
It seems that Blackmagic Design has its own accessories to facilitate the use of this camera.
Check this out: https://www.blackmagicdesign.com/fi/...sa/accessories |
Oh something on that page gives me an idea... Thanks!
Over 16lbs with no evf/grip or shoulder mount. And of course no batteries, lens or NDs on that yet.
Strange camera!! |
When purchasing URSA, do I get along with the body a battery, a battery charger and CFast Card?
I doubt it. I didn't see anything about a battery except re mounting plates for V-Lock or AB batteries and I'm sure there's no media included.
I think this is a case where you spend $5k for the body and another $5 - $10k (or more) to have something you can actually shoot with. My take on what you can expect to get from BM is basically a sensor in a shell with some firmware and a couple of control buttons. I think they're pretty much in the business of selling a sensor with a lens mount and display and a few buttons, not a complete camera. |
The Ursa is in stock at B&H. |
I'm lost at why manufacturers are selling/designing cameras without viewfinders or with quite bad ones!
I can mount a monitor on the far fewer occasions that I need one. What I need is s really nice well thought through view finder. Of course you can add after market but they never seem to integrate ad well. As far as the Ursa...why that huge screen? Baffled ! |
Do I read correctly that there is no way to use the iris on EF mount lenses, outside of a "momentary auto iris" button, and no plans to institute iris control? Am I missing something?
I think, particularly in the case of BM, they aren't selling cameras. They're selling a sensor and I/O block with a display of sorts and leaving it up to the user to build a real camera around it with parts sourced from third parties. Their motto should be "Every man a systems integrator"
Sort of like RED selling a "Brain", except you can get all the other parts from RED and they've been engineered to work together. Unlike BM. Not that this is necessarily a bad thing, you just have to understand the business model and not be surprised. I have three BM "devices" so I'm obviously OK with the concept. |
Hi Haitham - here's a post where I list everything you need (Blackmagic shoulder kit, 2 x 32GB CFast 2.0 cards, a CFast 2.0 reader, a V mount battery plate and an inexpensive V mount battery solution):
If you want a cinema camera below $8000 that can also do weddings, I recommend the $5995 Blackmagic URSA EF mount with the $345 shoulder mount kit as pictured here: https://images.blackmagicdesign.com/media/products/ursa/accessories/batt... (link is external) You'll also need a couple of $180 CFast 2.0 cards, a $50 Sandisk Extreme Pro CFast 2.0 Reader/Writer, a $185 V mount battery plate and a V mount battery solution of some kind (I would get a couple of $10 Sony NP-F550 batteries (link is external), a $50 NP-F to V-mount adapter (link is external) and a $17 dual battery charger (link is external)). With $349 Rokinon 14mm T3.1, $479 Rokinon 35mm T1.5 and $309 Rokinon 85mm T1.5 lenses, you will have a very capable Super 35mm camera for a little over $8000 - with Ultra High Definition "4K" at 60fps, built-in XLR jacks, the ability to record to 12-bit RAW or 10-bit ProRes. With this list, you can be up and running for a little over $7000 body-only. Good luck! Bill |
In fact, I am very much fascinated with URSA and have a big intention to purchase it. What makes me hesitated are some physical and technical attributes which I consider them drawbacks, such as heavy weight, no included battery, no view finder, no shoulder mount, etc.
It is quite early to arise this question but I find it necessary to do so before having any decision taken in this regard: is there any difference between URSA and Production 4K in terms of image quality (i.e. sharpness, color space, etc.) |
Speculation on my part but I suspect they'd be pretty close assuming the same lens.
Does URSA have built-in audio, or is it necessary to purchase an external microphone?
This review from Faymus Media should answer a lot of your questions:
