Shooting RAW with the BMPCC
My experience shooting a video with the BMPCC in RAW mode:
taking RAW Video Using the Black Magic Pocket Camera Many of the reviews I have seen, because of the newness of the RAW capability, are actually not pertinent to RAW shooting. The BMCPCC is really made for RAW. |
Re: Shooting RAW with the BMPCC
Interesting read, eventhough this raw camera looks like a "fix it in post" camera but I wonder if it really is, take the whitebalance f.i., as I understand you can only set some presets but since it's raw you can push it easily to any other colour temperature, but how do you know when white is white? when is a shirt grey or a bit grey/blue when you have set the wrong whitebalance and want to fix in post? Since the raw footage is so colourless to start with is setting the right whitebalance during a shot not important?
Also about focus, you write "As a run and gunner I exclusively used AF (with one exception). We will see if subjects are in focus." From what I have read so far it seems to be difficult to judge focus with this camera and out of focus footage is not repairable, not even in the mighty raw. Why would you take the risk of letting the camera handle the focus? Is it in fact so difficult to critically judge focus on this camera? |
When I use AF what I mean is I use it and check it - sometimes I have to "push" to get it to focus right (in that sense it is no camcorder), but I think I can tell when it does (the proof being when I see the video). That method is still much faster *and* more sure than my turning the focus ring back and forth to get focus, after enlarging.
The bottom line now that I have seen rough cuts is that it worked fine - nothing I wanted to be in focus was not. |
BMPCC Sound Check
This video was taken to assess the sound quality and the synchronization of the BMPCC *in-camera* audio and video after processing the RAW frames. The players were using all percussion, so this is perfect for checking synch:
Color-corrected in Lightroom, merged in Vegas Pro. The opening shot is terribly shaky - the Panasonic 40-140mm OIS lens does not do a good job on this camera fully zoomed. The sound test passes - perfect synch, and good dynamic range and transients from the BMPCC audio track. Focus is fine too. More challenging video to come. |
Mark, was this Pocket movie using the built in mic or an external mic? if ext, what mic did you use and where was it placed?
The internal mics were used. I am not recommending this for the most serious audio, but for run and gun it seems as good as the Canon EOS M, for example, and much better than the AGC audio of most camcorders and cameras.
It does have both external mic in and headphone out, but no meters! |
Re: Shooting RAW with the BMPCC: WB
The trick is to set the wb with a scene that does have a white reference (white shirt, white paper, white tent) and then use that same temperature setting for all of the scenes with the same light (or make a pre-set, just like many consumer cameras have, but customized for your setting). In shooting, therefore, you may want to make a short clip with some white subject matter in a setting you will be shooting, or use a white card, of course. It becomes second nature to do that. The point is you do not have to individually guess the wb for every clip, and you do not have to have white in every clip. I would suspect that doing this in post will give a lot more accurate wb than in-camera auto wb. And simply shooting a short scene with white is no different than setting wb by a push method. |
Mark,
Could you tell me the workflow you use for audio synch with the cinemaDNG raw files in Sony Vegas? Thanks |
I import each folder with the uncompressed tiffs, converted in Lightroom from the RAWdng's, as a string of photos, which Vegas recognizes as a set of frames for a video clip (because I tell it so - see below). Note: Vegas recognizes tiffs but not dng's, so it is necessary to have converted the individual dng's to something Vegas recognizes. I also import the associated audio file (.wav) from the sd card. I put the video clip, consisting of the set of tiffs (frames), on the video timeline. I also put the.wav file on the audio time line, and they jump to align perfectly when I move them together. I then make the vertically-aligned two tracks (video and audio) for the clip a new Group, by right clicking on the selected two tracks. They then are locked together and move together. In importing the folder of .tiffs, you have to tell Vegas that each tiff is a frame and what the frame rate is. It all works well and simply - no need for any listening or going back and forth with a slider. |
Shooting RAW with the BMPCC: The Video
The Raw Video:
The first-generation compressed MP4, 108030p H264, HP 35Mbps video rendered in Vegas Pro from the uncompressed tiffs can be downloaded. This video consists of many shots I would not take with the EOS M or GH3 (my current video cameras) or any other camera - shots that are strongly backlit or that have both bright sunlight and shade at the same time. It is a test video, for the kind of shooting I like to do. 1. The OIS on the lens (Panasonic 14-140mm) does not do well at the telephoto end. There is more shakiness in this video than I would like, and that I normally experience with Canon IS lenses (on Canon cameras). But it is working. 2. You can get color! 3. The in-camera audio is at least as good as the EOS M or the GH3, which is very good. There is a real sound track that adds ambience and thus realism, and even some music. 4. Auto focus is fine. No problems at all. 5. No moire or aliasing in these shots. 6. More resolution and no visible sharpening artifacts compared with the Canon EOS M or any other camera I have used for video (not better than the TM900 camcorder). I used the default sharpening in Lightroom, which is light. 7. One can shoot run and gun, with in fact little attention to wb and exposure that you normally would have to fuss over in the field, but you need a lot of leisure time and patience later. |
Is it just me or does all the footage I see from the BMPC have very deep blacks, or crushed, or even heavily clipped?
Dunno if the camera is like that or it's just the way people like to grade it. (But people seem to all be grading it the same way?) Does everybody agree that they are truly getting 13 stops of dynamic range? (anybody disagree?) CT |
Re: Shooting RAW with the BMPCC: The Video
Shooting RAW with the BMPCC: It's all in the editing
If one is shooting RAW what you see it is all in the "color correcting" or "grading". You can do just about anything to the flat picture you get from the camera, which is the point of RAW. So what you see is all user choice (or competence) in the edit.
My experience is that most of the BM camera videos I have seen have weird and/or pale colors, sometimes masquerading as art (including those from reviewers like Philip Bloom). The video I posted was in fact meant to contrast with that stuff, and mimics what you get from a Canon DSLR, but with less moire and more range and more accurate colors, retaining though the contrasty, bright look of real life (enhanced). It is meant to be a video, not a film-look wannabe. But one can do anything with it, and it is ok not to like it. It is also the first time I have ever used the camera (and the shaky lens was a surprise). |
BMPCC Low-Light Video: Shopping in Grand Central
Shot using RAWdng, graded and rendered in DaVinci Resolve Lite. 108030p, 180 degree shutter. ISO800.
Panasonic 20mm f1.7 lens (non-IS, as is evident in a few shots). Grand Central Terminal is very dark. Worse, it has many small areas of bright light - sun-lit windows (during the day) and small, bright backlit signs. Almost any view will have bright parts and very dark parts. It is a real challenge for dynamic range. The last scene in the video is the biggest challenge - a dark room with large bright white lit signs in the background. The Vimeo version, from where you can download the 35Mbps .mov file (h264), with uncompressed audio: The Youtube version: I uploaded a 235Mbps video to Youtube (as it has no GB limit), so the original here is of higher quality. Select 1080p. |
