-   Avid Editing Family (https://www.dvinfo.net/forum/avid-editing-family/)
-   -   Unable to export long sequence! (https://www.dvinfo.net/forum/avid-editing-family/84199-unable-export-long-sequence.html)
Tony Pham January 18th, 2007 02:56 AM
Hi everyone,
I'm working with 1 and half hour show and experencing difficulty when trying to export self-contained QT file. The system just froze when at 100%. I got enough hard drive space and did the video and audio mixdown before export but it keeps freezing when the export almost done. I tried to export a shorter segment of the same sequence of about 5 min and it works fine. Please advise on what to do. Thank you very much!
BTW, I'm using Mojo SDI with Avid 5.6.2 and Quicktime version 7.0.4.
David Parks January 18th, 2007 02:01 PM
Tony,
What QT codec are using? Are you planning to import the QT into another application? And if that application resides on you Avid computer you can use a QT reference, which is much much quicker export and refers to your Avid media files, better quality.
David
Tony Pham January 18th, 2007 04:47 PM
Thanks David!
I'm using "same as source" option with "Avid Codec" to export since I'm working with DV50. I can't use QT ref file because it will be use on a different computer. I'm advised to use QT version 7.1 to solve the problem, do you think it's the case? Thanks!
Richard Alvarez January 18th, 2007 05:02 PM
Tony,
Have you logged onto the Avid forum with this? www.avid.com I'm thinking the upgrade to QT7.1 MIGHT solve your problem.
Tony Pham January 18th, 2007 05:38 PM
I did, Richard! I will try it out tonight to see if it will solve the problem. Thanks!
Tony Pham February 6th, 2007 02:59 AM
Thank you very much, everyone! QT 7.1 doesn't solve the problem. However, exporting the sequence with video only worked. Thanks again!
