Antony,
Why might that be? Do you know Angers? |
A little bit - enough to be jealous!
What kind of work do you shoot in London?
Do you have a website for your company or work you have done. Every now and then I'm over in London and would be good to have another contact in that neck of the woods. Simon |
Mostly broadcast work and mostly editing. I've sent you a PM with more information.
My university just got the HD100s in, but my tutor said we can’t shoot in HDV yet because Avid systems don’t support it yet. We currently use Avid Pro HD 5.1.
I thought they it did support it, just not 24p? Also, I mentioned that we could shoot in HDV and down convert to SD which would produce better picture quality that shooting in DV (what I have researched) He disagreed with this. What’s true? |
Does Avid support HDV in PAL countries? I was under the impression that 25 fps is not supported, only 30 fps. What part of the world are you in, Simon?
Hi Jiri
Don't get excited! No 24 OR 25fps support yet. Last I heard (from a decent source) is January. As we know, Avid does support 30fps but not very well! At Simon Antoniou - I also agree with you and not your tutor. If you shoot well in HDV then you can end up with better SD pictures than if you shot in DV but that only applies if the post method is right. That post method isn't really accessible to you via Avid unless you use Liquid (or a lot of fiddling about in 1080p). If you cannot edit HD then you can't down-convert at the end for best results so that means totally SD post. Remember that you cannot downconvert for ingest via firewire using the camera or the deck as you can with Sony HDV2 gear. The only easy method of down-converting is via analogue (YUV) and you can only maintain TC with the deck (RS422) not the camera. For this you will need Mojo analogue or the Adrenaline box with MC. The D to A conversion is not so great on the deck (neither is frame accuracy on capture) and back in again on the Mojo so you'll end up with worse SD than if you shot DV in the first place. Better down-conversion is available via SDI using an HDV to HD/SD SDI interface (such as the Convergent box) for which you will also need Mojo SDI or MC Adrenaline. Bottom line, if you need to edit soon and you don't have alternative NLE systems available to you, I'd take your tutor's advice and shoot DV if you want 24p or 25p unless you have access to an HDV-HD/SD SDI converter and an Avid workstation that can capture SD SDI. |
I would prefer to shoot in HDV at 30 fps. Rather than DV at 24p. The latest version of FCP support HDV 24fps right? I might just edit on my friends mac if I can. |
Sorry Simon, we were posting at the same time. Yes, definitely use the Mac and FCP and shoot HDV1 if that's a viable option. Oh, and if you are in the UK and you shoot HDV1 30fps you WILL be sorry!!!
I thought it was just a case of shooting HDV, edit, then just put on a DVD. Which is the downconverting. Not as messy as that.
Thankyou very much for the info. |
If you go with FCP, then you can do just what you say - ingest and edit in HDV/HD and then encode an SD MPEG2 file for DVD. Much simpler. |
Just to add a Mac NTSC experience (nightmare, hassle, whatever you want to call it...);
I ingested and edited in HDV and really wanted to go from there to DVD but in the end and after trying all source of transcodes to DNxHD codecs I had to "Export to HDV Device" and re-capture the project from tape downconverted by the deck to SD. After that, it was a simple QT reference and DVD encode. I sure hope that Avid will wake up and do something real soon! |
My guess is that one of the reasons it's taking Avid so long to implement 24 and 25fps HDV1 is because the existing 30fps support is so weak, they know they have to re-think. Jiri's experiences confirm this suspicion for me. Also, Jiri - I believe that the best DNx codec you have in 720p/30 HDV projects is 110?
