Importing Pro into Liquid
Ok, so I have editing and completed my clips on Avid Xpress Pro, can I import all the clips into Liquid and use its DVD authoring application and burn from there?
Will there be any changes? Such as effects? Thanks |
I have not used avid xpress pro myself, but I'm accustomed to Avid Liquid. If you are able to make an avi-file which contains all your effects, you can then import it into Liquid and use the dvd-authoring app + burn it there.
I heard from someone that it is not possible to import your project from xpress to liquid, so you have to finish all your editing work before you import it into liquid. Hope this make sense to you. |
ok, say I dident want to do that. What DVD Authoring programm is recommended for easy use and good results?
Thanks for any help. |
For price, ease of use and efficiency one of the best programmes is DVDLab Pro (in my opinion......) However there are probably many other good cheap programmes out there. |
thanks guys..
