-   Avid Editing Family (https://www.dvinfo.net/forum/avid-editing-family/)
-   -   Capture in DNxHD? (https://www.dvinfo.net/forum/avid-editing-family/476110-capture-dnxhd.html)
Steve Kalle April 2nd, 2010 08:34 PM
Capture in DNxHD?
I am trying to decide between a nanoFlash or Aja Xena for recording greenscreen. If I go with the Xena, I don't want to record uncompressed so I was wondering about DNxHD. FYI, I am using a PC (Z800) and edit in Premiere & AE CS4.
Also, does anyone know if TMPGEnc supports DNxHD as a source?
Are there problems editing and encoding DNxHD in Premiere or AE?
Peter Moretti April 4th, 2010 12:38 AM
I can only answer one of these ?'s. TMPGEnc Xpress 4.0 works very well with DNxHD.
Good luck w/ everything else :).
Devin Termini April 4th, 2010 05:03 PM
I've used DNxHD in Premiere. It works, but not as well as it does in Avid.
The last time I tried, the DNxHD clips looked as if they were under-exposed. Played the clips in quicktime - fine, no problems. Only in Premiere do they become dark. Strange. Didn't have time to fix the problem with the decoder. Transcoded to another format and continued editing.
I know that DNxHD is free to use, but if you're gonna be using Premiere, consider using CineForm. AFAIK it is made to be used with Premiere.
John Mitchell May 5th, 2010 06:06 AM
DnxHD is an Avid editing codec. Neither the Nano or the Xena records in DnxHD. The lack of a true portable recording solution for DnxHD is a missing link in the Avid range.
Premiere in it's latest iteration (CS5) should provide support for the Sony MXF format the Nano records in, otherwise there are third party solutions for older versions.
