Avid MC3.5 and EX at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old March 6th, 2009, 08:57 PM   #1
Avid MC3.5 and EX
Hello,
Anybody out there using the new MC 3.5 software with EX media? I'd love to know how the AMA workflow is working.
Don
Don Hardy is offline   Reply With Quote
Old March 7th, 2009, 02:30 AM   #2
Originally Posted by Don Hardy View Post
Hello,
Don
I've tried it! It's brilliant. It will probably change my workflow altogether.
Before the AMA-feature my workflow was this.
1. Offload cards using Clip Browser to HD.
2. Make backup of BPAV folder to second HD.
3. Convert clips to MXF into a temporary directory on a third HD.
4. Import MXF clips into Media Composer.
This meant copying to media 4 times before starting to edit. It also meant using at least three times the drive space of the original media. (After throwing away the MXF-files).
Now - with AMA I can remove almost all of these steps! I can actually get away with no file copying at all.
One workflow is this.
1. Put SxS-card into laptop.
2. Use AMA feature to browse to SxS card ant point to it. Wait 5-10 sekonds and voila - the clips show up in a bin and you can start editing straight from the card.
Of course you will need to consolidate your edit when you are finished if you don't want the card to remain permanently in the reader. This would be great for news. Absolutely NO off load time.
The workflow I will be using will be very differnt from my old workflow.
1. Offload clips to HD. (My fast Avid Media drive)
2. Make backup to another HD.
3. Use AMA to point to the media on the fast Avid Media drive. And start editing.
The great thing about this, apart from only having to copy the media twice instead of four times (With shotput you can do this in one go) is that I actually don't create Avid media files ever. The media remains in it's original BPAV-format forever. This means that if my media drives crash I don't even have to relink the media from a backup. All I have to do is plug in my backup drive and point to the media on my backup and I'm of again. A couple of minutes of lost editing time.
AMA has also meant that all of my archived footage since I bought my EX1 now is online instead of requiring at least two file copies to be available in the Avid. All I have to do is use AMA to point to it on whatever drive it is on. I've even managed to point to media on our backup NAS over the Gigabit LAN and use it for editing.
I find AMA revolutionary and I truly hope that there will not be any flaws or bugs in the feature that show up with time.
Ola Christoffersson, Kamrat produktion, Stockholm - Sweden
www.kamrat.tv
Ola Christoffersson is offline   Reply With Quote
Old March 7th, 2009, 10:12 AM   #3
The AMA workflow is brilliant. Finally a cross platform solution. I primarily use FCP for my projects but this work flow will be excellent for projects where you may want to do an "off-line" on one system and then do the finishing on a more advanced system. Also really fast for news etc.
Old March 7th, 2009, 10:48 AM   #4
That sounds interesting Alister. Can you please elaborate on how you would do this? How would an Avid-project using AMA transfer to FCP and vice versa?
www.kamrat.tv
Old March 7th, 2009, 11:23 AM   #5
Sorry, I meant using Avid instead of FCP. I can't see a way of sharing the Quicktime .mov XDCAM files across platform, whereas if you cut on a Mac with MC3.5 you could then transfer the project to a PC with Avid.
Perhaps one day we will get native support for .mp4 and MXF's in FCP as well. I don't really understand why the files have to be re-wrapped to .mov to work. I guess it's some quirk of the OS.
Old March 7th, 2009, 01:07 PM   #6
Of course - I was thinking Avid/FCP when you said cross platform, not Mac/PC.
Yes, it seems like Avid for once is one step ahead of FCP when it comes to EX implementation. About time if you ask me! :-)
www.kamrat.tv
Old March 9th, 2009, 01:28 PM   #7
Thanks guys,
I'm really excited about the possiblities of the new AMA workflow. It seems like Avid might have gotten this one right...
Best,
Don
Old March 10th, 2009, 12:34 PM   #8
I may be missing something re the workflow described above...
I'm sure I'm not the only one who will want to back up every BPAV folder to some other hard (not the one I'll be using for editing) before I start to edit. Does the AMA allow you to do this?
Thanks, Malcolm
Malcolm Hamilton is offline   Reply With Quote
Old March 10th, 2009, 02:09 PM   #9
Thanks, Malcolm
Yes Malcolm, I think you missed number 2 in my new workflow (see below).
"The workflow I will be using will be very differnt from my old workflow.
3. Use AMA to point to the media on the fast Avid Media drive. And start editing."
However for quick turn around news I would not hesitate to edit straight off my SxS and consolidate when finished. Betacam SP-tapes have been used like this in news for decades and I would think an SxS card is even less prone to loose data in a short time perspective.
www.kamrat.tv
Old March 10th, 2009, 04:25 PM   #10
If you use Shotput you can off load to up to 3 separate locations at the same time, so you can make your working coy plus backup copy in one hit. While that is happening you can point Avid at the SxS cards to start editing. Once the copies have been completed simply point avid to the copies to continue editing.
Old March 10th, 2009, 06:11 PM   #11
It really does work quite well. I just setup up my laptop today and I'm been experimenting with 1080p 24 footage and 720p 30 footage and both work really well off on SxS cards, MxR cards and external USB drives. BTW, my laptop is a very average HP machine...nothing fancy.
This is a huge time saver and a great way to save HD space too. Well done Avid.
-Don
Old March 10th, 2009, 07:24 PM   #12
very exciting... thanks for the tips. I'm in the middle of a project so I'll try to wait until I've finished before upgrading to 3.5. But it's going to be hard.
Cheers, Malcolm
Old March 13th, 2009, 02:39 AM   #13
AMA broken!
I have been very excited about the new AMA-feature of MC3.5. It's a great way to access P2 and XDCAM EX-media!
However, my excitement has turned into disappointment in the last couple of days due to the discovery of two serious audio problems that are probably related.
1. When applying an audiosuite effect onto an AMA-linked clip the MC freezes. After downmixing the audio this works well. I have not had this confirmed from other users. Please report back!
2. This is the serious and almost unbelievable one! When editing with AMA-media from XDCAM EX it is not possible to move or edit the audio into other tracks than track 1 and 2. If the media ends up on other tracks than 1,2 it is MUTE! The wave forms show but playback is muted. This was pointed out to me by another user in this forum and I just confirmed it. More confirmations would be interesting. How about P2?
I'd be very interested in confirmations on these two problems and especially would like to hear Avids view on this. How is it possible that you have released this feature without finding these problems?! When will they be fixed. As of now AMA is a useless feature.
www.kamrat.tv
Old March 13th, 2009, 03:33 AM   #14
I use Adobe Premiere CS3 together with a Matrox RTX2 card. I just transfer the clips to my computer using ClipBrowser and then open the clips in Premiere, no conversion is needed.
Premier has EXCam EX presets which cover all the EX formats.
Using the Matrox HD presets you can also bring in the EX clips but these are limited to 1440x1080 and 720
Old March 18th, 2009, 08:53 AM   #15
Hi Ola,
I'm curious about the problem you describe (wanting to upgrade to Avid 3.5 but still leery).
If you use AMA, but copy all the media you'll be editing with onto an external drive before you start editing, and if Avid knows that this is the media it's to use, then do you have this problem with muted tracks?
Thanks, Malcolm
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
