Help w/ Importing AVCHD in FCP 6.0
I recently purchased a Canon hf s10 and I'm having difficulty importing clips into FCP or IMovie.......I prefer FCP, but I wanted to see if it would work with IMovie as well.....I have a dual core Intel Mac Pro 2.66 GHz...........I plan to buy neoscene, but for now I thought I'd test out some footage...........Does the AVCHD format work in FCP 6.0, or will I have to upgrade? When trying to import I receive an error message stating "Invalid directory structure. Please choose a folder where directory structure matches the supported media."
Thanks for helping, Reggie |
You need to update to 6.0.2 or later (latest update is 6.0.5) in order to import AVCHD via log and transfer in FCP6. I have G5 and samples of AVCHD can be transcoded using Toast 9 or 10.
Thanks alot Robert, I presumed I would have to upgrade. I wasn't sure if there was a workaround
it's not an upgrade from FC6 ... it's just a software update. Works great with log and transfer.
Just curious. How's it going with your new HFS10. Did you figure out a work flow? Is the transfer working OK now...Let's see some test footage. |
Hey G. Lee it's going pretty good so far....I'll post some footage soon
| All times are GMT -6. The time now is 05:44 PM. |
