Tom,
Glad to hear that you like VS X2 Pro. It also amazes me just how much more capable it is compared to Adobe Premiere when handling AVCHD. The range of effects, transitions, filters, and other neat capabilities is especially impressive considering how little they charge for it. Nero and PowerDirector 7 from Cyberlink are also extremely capable, and make the bug guns like Sony Vegas, Premiere, and Final Cut look limited or bloated in many ways and vastly overpriced. My HF100 does not have internal memory, so I merely read the SD card into my Dell at 30 Mbytes/sec and directly use the .mts clips with no driver issues. It is very fast, and much better than my HDV work with other camcoorders I have here. I absolutely love this little HF100 and the workflow which takes me from shooting a clip to watching an AVCHD disk on my BluRay player in less than 10 minutes. You do not need a special burner for AVCHD disks, and can make them with the same burner you presently use for SD. All you need is a player which supports AVCHD, which many if not most BluRay players provide. Then you can watch your content in full blown HD with the same quality as it comes from your camcorder directly at 1920 by 1080p. I loved your comment about Quantel offering a building. Talk about a video editing accessory..... Larry |
Mike Burgess |
Mike;
I am buying it directly from Corel. I think the Pro version for $99.00 is worth the extra cost over the standard version. VideoStudio X2 - Video Editing |
Mike |
You definitely need the Pro version to do HD work. I too bought all of my Corel and Ulead software directly from them on the web.
Larry |
Mike B. |
Glad to help, Mike!
Peter,
For whatever it's worth, I have never seen this problem either in the new X2 or the older 11.5 version of Video Studio Pro. I went to the Ulead support forum and found the long thread where some other users have reported the same problem. One of the posts describes the "solution" he came up with using Nero Vision as an intermediate. I downloaded his "before" sample .mts file, and cannot see any stutter effect on my machine at all using 3 different players I have here for AVCHD. It may be that some machines have hardware or software issues which show up in this way. Perhaps a marginal processor or video card. Perhaps a codec not playing properly. I realize this answer does you no good in terms of solving YOUR problem, but I would also be glad to take a look at your file if you want to post it someplace. My HF100 files all seem to edit without this problem, and I always use Smart Render, try to do cuts-only edits, and have made tons of AVCHD disks. I would definitely ask Corel for their support in fixing this, and several other people are obviously experiencing the same issue. Larry |
Hi Peter,
Does the stutter occur in the final video or in the time line? So far, VSX2 has been just perfect for AVCHD, in some ways, surprisingly so. It's quite an inexpensive application - mine was an upgrade, even better an upgrade on sale. I use VSX2 for a multitude of common tasks - ripping DVDs, DV to DVD Wizards (for legal work), it recognizes some of the more oddball CODECs conversions that come our way, too. I highly recommend it. For the low cost, I find it a no-brainer. My best to all. Mike |
Ratios still 0%
Hi Larry Sorry I've been away from this for a while. But I made the changes you suggested and my ratios are still 0%. Any suggestions? |
Jamie,
Please create a very short (maybe 10 second) clip and either email it to me or post it on a website where I can download it. Since you camcorder is the oldest / very first AVCHD model, and uses 1440 by 1080 rather than 1920 by 1080 resolution for HD, I want to see what if any options I can find to avoid having the re-rendering penalties. Thanks, Larry |
Jamie,
I privately emailed you my email address using this forum's mail system if you should choose to use this method to send me a short clip. Larry |
Hi, Mike. The sutter occurs in the final rendered video. Oddly, I don't seem to get this stutter with VS11+ or with Pixela bundeled software. I wonder if this problem only occurs with Canon HF100 produced video. Larry, thank you for offering to take a look at my video. I will post an example soon. |
| All times are GMT -6. The time now is 06:50 PM. |
