Panasonic HDC-SD9 and over-saturated greens
I am wondering if other users of Panasonic's SD9 have experienced color issues similar to the one I describe below...
I have only had the camera for a few days and am testing its feasibility as a second camera for the HVX. The SD9's poor low light performance has been reported elsewhere and I can live with it in that regard. What may be a deal-breaker is its handling of color, specifically green. The white balance controls do not do the trick. The greens are so saturated and at times distorted that I'm wondering if there is an issue with my camera or if this is what all SD9s looks like. As it turns out the SD9's 24p mode cannot be enabled without also enabling the cameras "Cinecolor" mode. This mode increases color saturation. Almost attempting to emulate Kodachrome to my eyes. Even with the 24p and Cinecolor turned off, my SD9's greens seem off. Any SD9 users experience similar issues? Thanks, Matt |
Moderator, please delete this post, I couldn't find a way to do it as a normal user.
Do you have a short clip you can post that highlights the problem? |
Hi Matt,
I also have the same issue although it seams to me that the issue is in automatic white balance. If I use manual white balance (even on a non-perfect white) then the color is definetely less greenish - e.g. the sky is more blue. But, as am not an expert - how can one "proove" it? Gordan |
We loved this camera's capabilities and bought it to test it as a b roll to our HVX200 in the 1080/24p mode.
Unfortunately, our greens were yellow and blue. Totally unacceptable. Played with WB but in the 24p mode, nothing worked. Like Dave, the test footage we shot initially was in the store, and it looked good. Outside, however, things changed. It went back to Costco. |
I have an SD5, and I'm pleased with the color. I try to go with the fixed, but have been happy overall. Nothing even approaching the green issues mentioned.
| All times are GMT -6. The time now is 07:05 AM. |
