-   Atomos Ninja / Samurai / Shogun (https://www.dvinfo.net/forum/atomos-ninja-samurai-shogun/)
-   -   Lanc for Ninja Inferno? (https://www.dvinfo.net/forum/atomos-ninja-samurai-shogun/535859-lanc-ninja-inferno.html)
Alastair Traill May 9th, 2018 07:00 AM
I recently purchased a Ninja Inferno to use for natural history projects. I also have a BMD Video Assist 4K. The Ninja has Pre-roll and other features that make it preferable to the VA. However a feature I am so far missing on the Ninja but works well on the VA 4K is the ability to use a Lanc to start/stop recording. For the VA 4k I use a ProLanc and an early model Canon works also, neither work on the Ninya.
I have contacted the agent and my usual supplier but so far I have had no answers so my question is, is there a Lanc that I can use to start/stop recording in the Ninja Inferno?
Jeff Pulera May 9th, 2018 11:26 AM
Re: Lanc for Ninja Inferno?
I know that Atomos supports REC TRIGGER via HDMI with some cameras. Not sure if that would help you as I don't know what camera you are using, but definitely something to look into.
Alastair Traill May 9th, 2018 05:02 PM
Thanks Jeff,
In this case I am not trying to trigger the Ninja with the camera. I want to record what the camera ' sees'. Mostly I will be using a 'C' mount GoPro with remote focus control and remote control head for pan and tilt. At the moment I am using Infrared illumination and working in darkness with the camera 2-3 metres from the ground and maybe 0.5 m from some very alert wild animals. I am watching the Ninja or BMD screen 4-5 m from the action. Under these circumstances it is much easier to start the recording with a hand held remote like the Prolanc which is very compact and as used on the BMD flash regularly making it easy to find in the dark.
Alastair Traill May 17th, 2018 05:24 AM
I have had a reply the Australian agent who believe that this device should work: -http://www.gentles.ltd.uk/lancstudio/lancdirector.htm
It is capable of more functions than I have need for.
Alastair Traill June 2nd, 2018 05:39 AM
2 Attachment(s)
At the moment I am experimenting with a simple ‘finger guide’ with which I can hold my finger in place or quickly get my finger into place while I am watching my subject either ‘in the flesh’ or on the screen (photos below). I would prefer a switch on a lead but this is a useful start. It is made of aluminium and is attached to the ball head and sits about 8mm in front of the Inferno screen. I have modified the profile a number of times but this version has survived several recording sessions.http://www.dvinfo.net/forum/attachme...1&d=1527939487
