-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Canon Ee-s Dimensions (https://www.dvinfo.net/forum/alternative-imaging-methods/96616-canon-ee-s-dimensions.html)
Chris Knight June 15th, 2007 01:41 PM
Can anyone give me the dimensions for the Canon Ee-s Focusing Screen? Thanks.
Igor Babic June 16th, 2007 01:04 AM
Measures For Canon Focusing screens
1 Attachment(s)
Measures are:
38,5mm x 26,3mm
This is measured including pins on all sides, but excluding largest pin on lower side. Pin is 2mm biger then 26,3, it is 4mm wide and for canon Ee-S 11mm from right side of gg(including pins) to his left side.
On the picture is Ee-A. Now you can see difference, pin is on left side 15 mm from left side to pins right side. (you can also see little pin on right where is actualy pin for Ee-S). Shiny side is faced towards you.
Chris Knight June 16th, 2007 07:13 AM
Thanks, this is exactly what I needed.
Anmol Mishra October 1st, 2007 06:50 AM
Ee-A dimensions
Hi! Igor. Do you mind posting the complete dimensions ? For example, what is the dimension of the rectangle without the extensions on the pins. And the distance for the smaller pins on top. Thanks!
Originally Posted by Igor Babic (Post 697560)
Measures are:
38,5mm x 26,3mm
Igor Babic October 8th, 2007 10:55 AM
EE screen dimensions part two
Matte rectangle dimensions are 35,5mm x 24 mm. This is aprox. measured. It is very hard to accurately measure without damaging screens surface. Please try to draw all measures from my last post and and this post so you will get all measures you need. I will try to scan both screens so you can have all measures like this. I hope this helps.
Anmol Mishra October 9th, 2007 12:40 AM
Thanks for that - Igor.
Louis Demontez October 11th, 2007 08:21 AM
Anyone have any example footage when using the Canon Ee-s Focusing Screen in their DIY adapter?
Igor Babic November 3rd, 2007 05:24 AM
Canon screens scaned
1 Attachment(s)
Here is Canon EE-a and EE-s screen facing matte side. If you print them at 600dpi you can have exact measures of them. Here is obvious how much more light pass thru EE-a screen. I have put ruler under them so you can check your measure. This is scanned with HP scanjet G4050 without cover.
Anmol Mishra February 8th, 2008 11:42 PM
Are both the same dimensions ?
Hi Igor! I thought the EE-a and EE-s were slightly different..From the picture it looks like they have the same design.. Is that correct ?
