Any way to loosen the focus ring?
I have a SLR lens with a tight focus ring. It's okay if I rotate it by hand but a bit tough when I try it with a follow focus. Any tips on making the focus ring rotate smoother? Thanks.
What kind of focus gear are you using?
Is your lens and old metal rimmed Nikon?
These have a high viscosity grease on the threads which move the lens focus and when it goes dry and a bit of aluminium stain from wear gets into it the focus goes tight, more so in one direction than another. A proper lens service by a proper tradesman is likely needed. I got lazy, opened the lens and put a little drop of automotive transmission fluid on the thread to rehabilitate the grease as I was in a hurry. I was not concerned over doing damage as the lens was bought cheap with scratches on the front element. Despite that, it remains a good lens unless pointed directly towards light sources. It seems to have worked but not recommended as oil may seep out onto the glass or fractions may come off and condense on the glass surfaces inside. |
Focus gear is from Redrock, but follow focus is Cavision. The lens is an older Canon FD 55mm f/1.2. Glad that worked out for you, Bob. I don't think I'll risk transmission fluid on my lens. Are there any oil specifically made for focus rings? Love to hear more suggestions. Thanks.
I would check out this thread.
http://photo.net/bboard/q-and-a-fetch-msg?msg_id=0083xw The consensus is that if you're willing to risk doing it yourself, you can use a precision oiler from radioshack and use less than a drop of oil to smooth things out. However, most still recommend getting it done professionally. |
There is a bit of rainbow chasing in the process described on that website regarding Leica lenses. Placement of the lubricant has to be more controlled and precise.
With the old all-metal Nikon 50mm f1.2 and a 85mm f1.8, I took off the cover sleeve to expose the thread and key which stops the focussing element from turning with the ring. The small drop of lube was applied only to the fine threads directly and only to rehabilitate the original lube, not to replace it. |
I'll tell you what I did to loosen the aperture ring: removed the set-position pins that make it click at certain intervals, and spread grease on that sucker. Now I have smooth focusing across the entire range without having to be stuck at the preset intervals. Actually it's not grease, but the liquid steel component of JB Weld without the hardener mixed in. But it works exceedingly well. |
Ben,
Can you give more detail instructions? Like how did you take the aperature ring off? Thanks! |
Anyone know how to deal with the sticky aperature leaf on a Nikkor 50mm F1.4. In the Higher f stops okay, but when you open as far down as F 4, it will not go back without actuating the lever at rear of lens. I'm figuring I will live with it, but if anyone has an easy fix...
EDIT here it is. I did it to my 50mm 1.4 but all the Canon FD lenses basically look the same. http://www.frozenphoenixproductions....d_aperture.mov |
Wow, that's a lot easier than I expected. I have a set of Nikons... would they have a similar mechanism?
What would be the best liquid to use on the ring? The JB Weld scares me. :) |
sweet. I finally got this aperature mod done. I was pissed because I did knock the thing out of alignment and didn't know why it wasn't fitting together for a long time but everything is working now. This is awesome because one of my pet peeves while doing interviews outdoor is when clouds pass over the sun and I can't correct for this without the abrupt changes. Thanks Ben!
Also, regarding the focus ring. I tried the radio shack lube, I ended up using way more than a drop. I didn't take apart the ring so I used the corner of a sheet of paper to push the lube in there. It might be slightly better but not significant. |
| All times are GMT -6. The time now is 06:04 AM. |
