-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Letus w/ 35 Redrock FollowFocus? (https://www.dvinfo.net/forum/alternative-imaging-methods/95589-letus-w-35-redrock-followfocus.html)
Nathan Pawluck June 1st, 2007 07:50 PM
will the Redrock microFollowFocus work with a letus 35 flip. On a sony hvr-v1u?
Marcus Marchesseault June 4th, 2007 06:07 PM
A follow-focus does not interface with the 35mm adapter. The geometry that matters is the rail mount and lens gears. Since the Redrock FF comes with lens gears, the only variable is the rails. What rail system are you using? If it is standard geometry, it should work. I think one good thing to know is if the FF fits on 5/8" diameter rails as well as the standard 15mm. I have 5/8" rails, so there is some doubt that the Redrock FF will work for me.
Qiao Li June 29th, 2007 08:17 PM
hi nathan,
I have the redrock M2 as well as the LetusXL and I have been using the RR rods + FF with the Letus without any troubles. I'm waiting on my Cavision rods to arrive so i can test them with the RR FF too.
- Q
