-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   spinning diy adapter video (https://www.dvinfo.net/forum/alternative-imaging-methods/92811-spinning-diy-adapter-video.html)
Hurcan Emre April 30th, 2007 02:31 PM
adapter has a spinning disc, +1, +2, +3 macro and a small achromatic lens.
what do you think about the result? maybe i should try to find a better achromaticlens? or will using one +7 macro be better than using +1, +2, +3
16mb quicktime movie
http://students.sabanciuniv.edu/~hurcan/35mmtryout.mov
Chris Barcellos April 30th, 2007 04:45 PM
Hurcan:
I've got to say, you did a pretty nice job just with those lenses-- particularly preventing sharpness fall of at the edges. When you described set up in post, I was expecting some messy stuff..... Not sure if a plus 7 will change anything that much. I had a plus 10, that got really soft around edges.
Got a picture of your self built unit... Don't be shy !
Cole McDonald May 1st, 2007 08:23 AM
very nice...what are you using for GG and what kind of achromat are you using? pix of the unit?
Hurcan Emre May 1st, 2007 11:27 AM
my gg is grinded plastic that i took out from a cd case (thanks to Ettore Giraldi for the idea)
im using an achromatic lens that came out from an old binocular
here is an other video footage that i tested my 70/300 canon photo lens:
(7mb quicktime)
http://students.sabanciuniv.edu/~hur...canon_lens.mov
and here is the images of my setup (don't laugh!!) it's in the development procces thats why the parts are too scatchy :D .
http://students.sabanciuniv.edu/~hurcan/1.jpg
http://students.sabanciuniv.edu/~hurcan/2.jpg
http://students.sabanciuniv.edu/~hurcan/3.jpg
Chris Knight May 1st, 2007 12:17 PM
Those are some stunning results for a such a ghetto rigged setup. I'm very very impressed.
Wayne Kinney May 1st, 2007 12:42 PM
I agree, the footage is very crisp for the 'ghetto' setup.
Only real issue that stands out is the CA which is probably from the achromat you are using.
Well done, its downhill from here :)
Bob Hart May 2nd, 2007 09:45 PM
I love the toxic acrid smell of freshly hacksawed PVC pipe in the morning.
Hurcan. If you look through your hardware supplier's stock, you may find end caps for PVC pipe which are of thin walled material. There are two styles.
One is a thick material designed to withstand operating pressure. The thin walled caps are called dust caps in Australia. The thickness of these is exactly the thickness of the lug channel in the FX1/Z1P lens hood bayonet mount. All that is needed is to file out the hole and the gaps for the lugs.
Towards the end of this clip -
http://www.youtube.com/watch?v=CnweOEEqlRY
- you will see what I used and what I did. In this specimen, the cap is larger and the centre is offset because I used prisms and an offset path within a larger diameter tube.
Hurcan Emre May 14th, 2007 07:06 AM
Thanks for the info. I have been trying to find the parts you used in your adapter but i couldn't find the one that fits fx1. Maybe we have different pipe sizes in Turkey :)
Here is a new video. (that's about the city im living, "Istanbul")
http://students.sabanciuniv.edu/~hurcan/al/istanbul.mov
(34mb quicktime)
Hurcan Emre August 7th, 2007 12:13 PM
update
shot taken with new achromatic lens using 28-80 f3.5/4.5 canon slr lens
http://students.sabanciuniv.edu/~hur...8_80_canon.mov
10mb quicktime
i acheaved acromatic color disortion free images. However i still need to make a proper gg to avoid ghosting. as you see
Jon Wolding August 8th, 2007 09:59 PM
Your bokeh looks pretty good, but you can see the arcing grain (shot of sky... stopped down too much?
Were you shooting wide open with that f3.5/4.5?
What do you mean by "ghosting"? I didn't see any double images.
Hurcan Emre August 10th, 2007 06:44 PM
the grain is probably becouse of the gg im using i touched it too much so i probably need to make a cleaner one.
by ghosting what i ment was the lack of sharpness and contrast :D
the lens has not got a diaphragm control on it so i think it is wide open 3.5 probably and when you zoom to 80 it becomes 4.5
and here are some more frame grabs but i still have a stabilty problem which makes it hard to adjust the adapter
http://students.sabanciuniv.edu/~hurcan/al/al2/1.jpg
http://students.sabanciuniv.edu/~hurcan/al/al2/2.jpg
http://students.sabanciuniv.edu/~hurcan/al/al2/3.jpg
http://students.sabanciuniv.edu/~hurcan/al/al2/4.jpg
http://students.sabanciuniv.edu/~hurcan/al/al2/5.jpg
http://students.sabanciuniv.edu/~hurcan/al/al2/6.jpg
http://students.sabanciuniv.edu/~hurcan/al/al2/7.jpg
http://students.sabanciuniv.edu/~hurcan/al/al2/8.jpg
Hurcan Emre August 24th, 2007 11:46 AM
here is the farthest point i could get:
http://students.sabanciuniv.edu/~hurcan/al/movmov.mov
19.3mb quicktime
caps:
http://students.sabanciuniv.edu/~hurcan/al/ayakkabi.jpg
http://students.sabanciuniv.edu/~hurcan/al/stun.jpg
no choromating abaration
no ghosting
just a little bit vignating which is the sideefect of using a 4.5f lens (and can easly be solved by using an condenser lens)
*some flickering (should be solved but don't know how)
*gg noise in sun light (should be solved but don't know how
*some suggestions please
Bob Hart August 24th, 2007 12:57 PM
Your f4.5 lens is likely to be a part of your problem.
Grain will be there in all adaptors, some more than others. Sometimes grain comes from the camera itself when the video gain is switched in.
Flicker can come from marks and uneven finish on the disk. A narrow lens aperture can make it much worse. If you have no f1.8 lens, maybe go to a camera store and ask to test a lens on your device in the store. You should observe an improvement.
I have a Nikon f4 zoom lens. It causes flicker outdoors in bright sunlight on a good glass disk I have made. There is no flicker with the f1.8 lenses. One lens which is f2.8 does not flicker but has corner brightness falloff.
Hurcan Emre August 24th, 2007 03:13 PM
thanks for the reply.
i have one 50mm 1.2f lens but when i have to shoot wide i have to use my old 18*80mm lens. maybe i should find a wide lens with a fixed focal lenght(maybe 20mm with a 2.8f at least)
i will try to make a better(or evener) gg so i may be able to avoid flickering.
thanks again
have a nice day.
Hurcan Emre August 26th, 2007 04:40 PM
new video with new gg and some color grading tryouts.
http://students.sabanciuniv.edu/~hurcan/al/eller.mov
10mb quicktime
Louis Demontez October 1st, 2007 07:57 PM
How do you actually spin the GG in such a small area?
