DIY: Component HD LCD field monitor for DOF adaptors
I tought that maybe someone would be interested in cheap HD field monitor?
Just buy a Actually I`m not pacticed this so it`s only a theory. Cheers, T |
You're not suggesting that that little adapter thing will turn a 640 x 480 LCD into an HD display, are you?
Tried it. It's fickle. And when it does work, absolutely nothing like a Marshall monitor. You get what you pay for.
This was mentioned before on this thread. |
I"ve been experimenting a bit with an 800x480 7" here. My first experiment with a passive component to VGA adapter did not work, but I'm going to give the powered adapter a go. I'll post up some high res pics of res charts and colour charts using the A1 output viewed via:
1. The 800x480 LCD using composite 2. The 800x480 LCD using component to VGA adapter (if it works) 3. The marshall HD monitor. I was thinking that an 8Mp still of each, with fixed exposure on the SLR should give a relative idea of brighness, sharpness, accuracy etc. So far I'm not thrilled with the cheap LCD. |
That's funny. I have a Xenarc and today I was thinking of getting that same component to VGA adapter for it.
That adapter is hot garbage. By the time your done screwing around with that setup you'll have a bunch of cables and crap hanging off your camera and nothing close to the marshall. I used that component adapter, I used one from audio authority, and another made for the xbox all of them pretty much sucked ass. I am in love with my Marshall though.
I agree Greg...it's a pile of cable right now. So far, for framing, it would be fine, and if you crank sharpness, an OK focus aid too. Colour and exposure evaluation? Forget it. I think the pics should illustrate that so others can decide what works for them. I'm borrowing the Marshall for a few days, and would expect it (just based on what I've read) to be a lot better.
I'm more curious on how different, if at all, the 800x480 will be via component-to-VGA vs composite. I'm guessing there's nothing too impressive going on internally with respect to scaling. I haven't seen a comparison done just based on high res photos of the displays under controlled conditions...so this should answer a lot of questions. Best price for the Marshall I can find in Canada is $1750...about what I paid for my first camera! Like everything, it will be a matter of comparing the pics, one's needs, and wallet size in deciding which is best :-) If I understand the Marshall HD 7" specs, it should be suitable for focus/framing as well as exposure/colour reference?? |
The Marshall is great for seeing more detail, but I give it a C for color and image muddiness. I think the Panasonic 8.4" lcd is the best (only?) option... and the most expensive.
Just had a quick peak at the Marshal vs the 800x480 LCD. Night and day difference. I'll post up the pics once I can try the 800x480 via the composite to VGA adapter.
