-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Stacked Macro filter? (https://www.dvinfo.net/forum/alternative-imaging-methods/81415-stacked-macro-filter.html)
Lau Ho Ming December 9th, 2006 11:46 PM
Hi. I uses a Sony PD-170 and my budget is very limited. I can barely afford a $60 macro lens.
So is Canon 250D have enough power to fill the canon ee-s screen on PD-170?
If I need more power. Is it a good idea to stack a Hoya +4 with Canon 250D? Will I suffer much image degradation?
Thanks for help :)
Bob Hart December 10th, 2006 06:42 AM
+4 Hoya may do it. Adaptor will be about 8 inches (200mm) from groundglass to front of PD170.
Is the Hoya one piece of glass?
When you stack lenses made from one piece of glass you get a not good image. It will be not sharp in corners. Colours separate in corners of frame. This problem is "chromatic aberration". For easy speak, it is called "CA".
This problem you see on an edge. A tree branch in bright sky will have wrong colours on one edge.
The achromatic dioptre lens does not cause this problem. An achromatic dioptre is made with two pieces of glass in one lens. Sometimes this lens will be called a "doublet"
Some people try to use lenses from large binoculars for acromatic dioptres.
Chris Barcellos December 10th, 2006 01:53 PM
Lau:
I have the VX2000, and have built my own adapter. I've tried stack closeup lenses, as well as ordered a +10 diopter lens from BH. The results, in limited situations can be okay, but there is so much problem at the edges that you will likely not be satisfied with the result.
If you check out Redrocks achromat, I think they have a SD acromat that for around $160USD. See:
http://shopping.netsuite.com/s.nl;js...c=2&category=6
Lau Ho Ming December 11th, 2006 07:31 AM
What about stacking an achromat with a single element macro?
Or how about the binocular achromat? I think their optical quality are not bad. Since anything related to camera are usually overpriced.
Bob Hart December 11th, 2006 08:15 AM
Ho Ming.
Achromat plus single element macro lens.? I think you may still have problems.
Here's a link to a forum which discussed low cost acromats awhile back.
http://www.dvinfo.net/conf/showthrea...+made+achromat
