Lens Recommendations for Letus35 XL
I am looking for recommenations for a set of lenses to be used with an XL H1 with a Letus 35 XL 35mm adapter.
This adapter will take Nikon AI or Canon FD lenses. Edit: I did find the following recommendations in another post: These are the fastest available in each lens...going up one stop, from say the 24mm f/2.0 to the 24mm f/2.8 , will save a good deal in cost, but you really want all the extra speed you can get with these adapters so here's the best kit you can get using actual focal lengths (no magnification): 24mm f/2.8 24mm f/2.0 35mm f/1.4 50mm f/1.2 85mm f/1.4 105mm f/2.0 |
