Is anyone using the HC1 w/ Letus FE
I am a video novice. However, I am picky about the look. So, I use the HC1 with the Letus Flip Enhanced (cheapest HD setup at time). It is difficult to light for this combination, atleast for me. I wanted to know if anyone hear is using this combination? And if so, how to you properly light for it indoors.
Also, I did a couple of small samples so you can see what it produces outdoors. Note: I'm still waiting for my follow focus so the video is a little shaky. first sample: http://home.comcast.net/~pwatkins1/f...ILER_LARGE.mov second sample: http://home.comcast.net/~pwatkins1/216.mov Camera: Sony HC1 35mm Adapter: Letus Flip Lens: Canon fd 1.4F |
What exactly is a follow-focus?
what is a follow focus?
A follow focus is a device used to focus your lenses without a lot of movement. here is the link to the one I ordered. I think it's the cheapest one out there.
http://indifocus.com/ |
From what I know you lose a @ least a stop using a 35mm adapter, and since urs is the letus Flip you will lose even more light. Thus for indoors, for every stop you lose, you will need double the amoun of light!
Btw the footage looks beautiful!!!!!!!! In full res is the 'focused' subjects 100% sharp and fully detailed to HD spec? Or is it slighty soft? Btw what music was playign in that long demo? Superman? It is so familiar! |
Thanks for the complement! The sharpness is cranked up. You can lose some sharpness because of the 35mm adapter, so I set it to offset that detail lost in the long clip. But, it is slightly soft in the short clip ( 2 spots) Btw what music was playign in that long demo? Superman? You are correct!! |
For the shallow dof alone, especially with ample light, a worthy enhancement IMHO. I'm shopping for one now for my A1.
Paul Watkins if you want filmlook try this setting
AS-4 reduce color level -3 reduce all the sharpness outdoor white balance +1 or +2 warm white balance always use 60 shutter speed...in case 24p conversion. min35 or letus may have film look but it sacarify too much of origianl image quality. |
Hi Jung, what is AS-4? Thanks for your tips on the film look. You've made some pretty spectacular clips in the past.
Also, do you use the outdoor white balance preset? Or do you do a manual white balance when you are outdoors? What about indoor shots - what white balance do you use indoors? |
How do you obtain a DOF like film?
AS -4 is manual exposure..it will look like ND4 filter without degrading image quality..
here's the sample.. http://www.camuser.co.kr/cam_vm/VID_.../11/indorr.wmv Zoom in 5x if need DOF |
How do I set the manual shutter speed to 60, mine is set on auto and when go to shutter speed tab is darkin out. Also +1 or +2 warm white balance.... how do I set this? Thanks |
How do you do manual exposure -4? I still don't understand. Also, following the other settings, the picture seems very dull and unsaturated. Are we supposed to boost up saturation in post? If so, then why -3 color in the first place?
This will expose at 4 clicks (i think thats' 4 half-stops, so 2 full stops) below what the camera would have done if you'd just left it on normal Auto-Exposure. |
Just use manual shutter set at 60.
But does anyone know how to achieve the film colors, esp. if the color setting is -3? |
