-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Hdrc (https://www.dvinfo.net/forum/alternative-imaging-methods/75236-hdrc.html)
Biel Bestue September 11th, 2006 07:17 AM
Hdrc
what you people think avbout those cameras?
www.hdrc.com
Frank Hool September 11th, 2006 03:15 PM
correct me ....i may be on very wrong track but 170dB makes about 28 f-stops.
Forrest Schultz September 12th, 2006 11:33 AM
are these cameras being sold??
Frank Hool September 12th, 2006 02:10 PM
You can use such camera to shoot straight to sun and same time having human face in shaddow(it's easy to imagine, if You remember pictures Your granmothers last tourist trip - how white can be the sky and how black can be a face). Both will represented in full imaginable range. The only problem is there's no device which could represent it in full range. No need ND-s or any other filter.
Biel Bestue September 13th, 2006 07:15 PM
http://www.brightsidetech.com/
there is also a process called tone mapping you convert an HDR image to an 8 bit image preserving the correct luminance in all diferent regions with diferent luma values
here is some info about HDR:
http://www.debevec.org/
how are HDRC's cmos sensors compared to RED's or ORIGIN's Dynamic Range wise? anyone has any idea?
http://www.hdrc.com/isensors.htm
Wayne Morellini September 13th, 2006 11:45 PM
Good find Biel.
Yes, I have been eyeing some Kodak sensors (one above SD) with 25micron pixels for this sort of thing, but this is more convenient. I am interested, but if that is not the sun behind the person in the sample shot, I am not overly convinced.
smalcamerasensor (now owned by Cypress, as is Ibis5a sensor) claimed 120db (previous top I heard of). Ibis5a, is around 90db with multislope. Micron has dual slope WVGA sensor. Pixim has some sort of scheme, too, with a number of companies selling cameras using it. I expect to see more companies with this. What is good here, is the large sensor pads, hopefully this chip has good Signal to Noise ratio.
Frank Hool September 14th, 2006 12:01 AM
i think, 170dB is far beyound anything whats existing at moment in the world.
Biel Bestue September 15th, 2006 01:30 AM
question is, what resolution have those things, in the tech page it seems closer but not up to PAL
and the other question is what kind of data the chip gives
what exacly is 170 dB intraframe and interframe? i mean what Intraframe and interframe mean?
Frank Hool September 19th, 2006 01:51 AM
Red's official dynamic range would be 66dB(about 11 stops). http://red.com/techspecs.htm .
Which is fraction of given 170dB.
Biel Bestue September 19th, 2006 03:23 AM
the big problem of HDRC chips would be their low resolution no?
http://www.mpii.mpg.de/resources/hdr.../hdr_video.mov
http://www.mpii.mpg.de/resources/hdr...HDRMPEG_hq.avi
http://www.cs.ubc.ca/~heidrich/Proje...R-Displays.mp4
tonemapping: http://en.wikipedia.org/wiki/Tone_mapping
what is Origin's?
Wayne Morellini September 19th, 2006 09:20 PM
I understand that the Origin is around the same, their site has some blurb about different ways of measuring latitude that lead some people to claim that a 11 stop camera is many stops higher, can't remember the details.
For now it is low res, we can hope they do a 720p big chip in the future, that might have less stops, but still be good.
Inter frame and intra-frame I don't quiet get, but intra frame is the only one we should be interested in. If they rely on sampling across many frames (accumulative or one frame slow shutter, next fast etc) then that is not so good, because you are relying on a comparison between frame intervals, and things move. For security cameras though, that would be great.
re-edit: The red spec says 66db or greater, so hopefully it has a good range.
Biel Bestue September 20th, 2006 02:31 AM
http://en.wikipedia.org/wiki/Video_compression
here it talks about inter frame and intra frame
it seems that intraframe is the most interesting, it's like uncompressed video
this is the 7th generation of the chip, i guess next generations (now that omron is producing them) will be more capable of higher resolution
