-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Using a prism viewfinder to flip the Letus image (https://www.dvinfo.net/forum/alternative-imaging-methods/74697-using-prism-viewfinder-flip-letus-image.html)
Paul Ramsbottom September 1st, 2006 06:15 PM
Hi everyone,
Just an idea, was curious about whether anyone had tried this?
I just bought a Letus35A, which Quyen custom built to suit my Sony HVR-A1U. Thanks Quyen, you are a God-send to the extremly budget-conscious film-maker and a very patient man.
Obviously you cannot do the magnet trick on camera and I am already running into the well documented challenges of how to focus and frame the inverted image using the Sony's small screen and view finder.
I was tinkering with an old Canon F1 35mm still SLR last night, which has a removable prism viewfinder. Out of curiosity I flipped out the LCD, turned it face-up and layed the Canon prism on top.
Obviously it is much smaller than the LCD screen but obviously it flipped the image and did a remarkable job of resolving the image. It magnifies the LCD very sharply and there would be little doubt that this would also be a most effective focussing aid, only problem is that it only overs a small portion of the 16:9 LCD.
This got me thinking, there was a company called Bronica who made a large format still camera called the ETRS. This camera had a horizontally orientated 6cm x 4.5cm sized image and a a variety of interchangeable prism viewfinders. I think Mamiya also had one.
I don't know the exact dimentions of the viewfinders but looking at pictures, I'm betting there would be a close fit with with the Sony flip-out LCD, and was debating whether I could vecro one over the LCD and use it to get good framing and focus.
Weight might be a consideration but I'm betting that a non-metered version with a plastic housing wouldn't be a strain.
Obviously it would prevent access to the Sony's touch-senstive panel but I am sure it wouldn't be too difficult to work around this.
I don't think the view finder is exactly 16:9 but it should be close enough.
Thoughts anyone?
