How to clean the Letus35 and vignetting
I'm satisfied with my Letsu35 (not the one with better achromat) but I found out it got some dust after a while. I looked for threads that dealt with cleaning this adapters but didn't found any. Can someone help? I'm afraid of breaking my adapter.
Also, I'm using it with a sony HC1 camera and I'm getting a lot of vignetting when using a 28mm canon FD lens (obviously more than with a 50mm). Is there any other way to reduce the vignetting than zooming in? Because, if I have to zoom it a lot to eliminate this, using a 28mm lens doesn't make much sense. I've tried using +1, +2 and +4 tiffen macro lens between the letus and the camera but there's still a lot of vignetting. |
take a screw drive and take it apart. Remove the end that has the GG. Use a can of compressed air. Wipe out the inside and the lenses with some alchohol and water.
Hey Mike,
I hope someone is able to shed some light on your vignetting issue, as I too am with an HC1 and was considering one of these adapters at some point in time. (but was wondering how the HC1 did with them) I put another posting in this thread http://www.dvinfo.net/conf/showthread.php?t=67069 thanks, jg |
Only workaround would be that You take few seconds wihte paper with given wide angle lens and use rcording as mask in after effect later to compensate appeared faal-off. |
