-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   Low Cost Rods (https://www.dvinfo.net/forum/alternative-imaging-methods/64470-low-cost-rods.html)
Will Hanlon April 6th, 2006 12:28 AM
Low Cost Rods
Anyone have a direct link to these low cost Cavision rods mentioned in the Shootout article http://dvxuser.com/articles/35/ for the Letus35 Flip. What are the cheapest but well-made rods available?
Will Hanlon April 6th, 2006 12:31 AM
http://www.bhphotovideo.com/bnh/cont...=335222&is=REG
Are these the rods recommended in the article? I need to stop answering my own questions. $159... anyone know of any cheaper?
Cole McDonald April 6th, 2006 09:59 AM
just build your own...
get some 15mm (about 9/16") aluminum dowels at home depot and use a die to thread the ends. Make to end caps with 9/16" holes 60mm (2.36" - 2 23/64") on center apart and throw a nut on each end of the rods, put on the end caps and another nut.
$15 cost, half an hour of work. Then just have to find or make a mounting plate for the camera...all the other standard rod mount stuff should just clamp on. If you can find a camera mount for < $100 you've already saved money...but you can probably make one for < $15. Camera thread is 1/4" - 20, have fun.
Dennis Wood April 6th, 2006 10:35 AM
Just a tip...if you can, use stainless tubing. Aluminum oxidizes in air and will leave black oxide on your fingers, clothes, camera etc.
Andrew Todd April 6th, 2006 12:33 PM
hey dennis.. you wouldnt want to sell a set of yours to a fellow canadian would oyu?
Matthew Nayman April 6th, 2006 01:23 PM
Cavision is $75 US for any length you want up to 24"
Not bad.
DJ Lewis April 6th, 2006 02:20 PM
Not bad.
$75. Rods only? Where did you see this price?
