1-inch CCD C-mount camera lenses
I was making a list of low light superfast lenses..Planning to use a 1-inch CCD GigE camera for making a film..
So far I have the Schneider Xenon 25 mm f/0.95 C-Mount Lens for 1-Inch CCD and Angenieux 25 mm f/0.95 C-Mount Lens for 1-Inch CCD Fujinon 16mm to 160mm f1.8 lens. "TV-Z" (Is this for 1-inch sensor cameras) Are there any other lenses from 1-inch sensor tube cameras I could use ? Would be great if I could troll ebay and pick some super lenses.. Quote:
the 25mm will end up as 60mm focal length on this sensor, and i doubt the f0.95 is very sharp. Also i think you'll find that f0.95 will be damn near impossible to nail focus in the field! f1.4 is good enough for a nice shallow DOF. I assume you're using the KAI2093 sensor? Which head? cheers paul |
The Fujinon 16mm - 160mm f1.8 TV-Z is as far as I know, only a 2/3" lens. I know it works on the Bolex for 16mm film and on the JVC KY-F50 camera head which is 2/3' optically relayed to 1/3" sensors. The resolution of this lens may not come up to your requirements.
It is older generation and softer than a prime lens, but sharper and better contrast than the ex-home video zooms I mentioned in the earlier post above. If you have a full 1" sensor to play with, it might be worthwhile looking at a C-mount >> Nikon adaptor and using some Nikon glass for your longer lenses. Their 35mm f2 is supposed to be as sharp as the older f1.4 at f2. Sigma for NIkon 20mm f1.8 is a bit soft wide-open. |
I've used a canon c mount adaptor with my 10-22mm which can produce good results on a 1" (obviously with the EF lenses they are open full as the adaptor cannot control the iris). However the 10-22 is a pretty slow lens and nigh impossible to manual focus (focus range is too short). Aside from that it's very difficult to find a wide and fast SLR lens. The best you're going to get is 14mm f2.8 or thereabouts. I think decent machine vision lenses are the best bet for 1" (all 16mm and S16 lenses have image circles that are too small -- i've had cookes and the 10mm f1.6 switar on there). I've not been able to test the schneiders though, would love to get my hands on one. And that computar zoom looks interesting (on the sumix thread)
a 35mm would be an 85mm on this sensor, which is too long for most uses. The 20mm more usable though. cheers paul |
c10x16a-snds21 Fujinon
I am going to use a Prosilica GE-1900C camera. I searched for 1-inch lenses.. This lens c10x16a-snds21 shows as a 1-inch zoom lens on Fujinons website..
http://www.fujinon.co.jp/jp/products...16a-snds21.pdf Would this work ? Also, if use a c-mount nikon adapter - how does the light performance go ? If I use a 35mm lens - not all the light that goes through the lens will reach my sensor..Thats why I am not too sure about adapters..Am I wrong in thinking this way ? |
the adaptor won't loose any light, it's just to phsyically get the lens on there at the right distance from the sensor. the image circle of the nikons will cover a lot more than that sensor though. You will experience a crop factor, each lens will have a field of view 2.5 times the stated focal length, so a 16mm fujinon will be more like a 42mm lens on a 35mm camera.
No light loss though. The prosilica is a nice head, i've been testing one for a few weeks, i'd be interested in hearing how you get on with it. I don't think that's the fujinon im thinking of, that seems to be a zoom, im talking about their range of primes. cheers paul |
Lenses
Can I check the exact details of the lenses you are using ? Like the model - that I can search for, and pricing ?
I am using it for a feature so I need a range of primes.. Help really appreciated.. Thanks! |
