-   Alternative Imaging Methods (https://www.dvinfo.net/forum/alternative-imaging-methods/)
-   -   HD100u and P+S Technik Lens Question (https://www.dvinfo.net/forum/alternative-imaging-methods/60626-hd100u-p-s-technik-lens-question.html)
Forrest Schultz February 13th, 2006 11:14 PM
When they did that test a while back with the JVC HD100u and the PS technik adapter(the test that has its own article on dvinfo.net) What kind of lens did they use between the adapter and the camcorder? thank you for help in advance.
Chris Hurd February 13th, 2006 11:39 PM
Hi Forrest,
The beauty of the P+S Technik Mini35 is that it doesn't require a lens between itself and the camcorder. The relay lens is already built right in to the Mini35. You've looked at the photos from this test, right? As you can see, there is no lens between the adapter and the camera:
http://www.hdvinfo.net/articles/jvcp...ini35test3.php
Forrest Schultz February 16th, 2006 10:57 PM
i know what you are saying, but what is inbetween the empty bayonet mount of the HD100u and the PStechnik. i mean, the dvx's lens is built in. but with the hd100u, you can swap lenses. what bayonet camera lens did the hd100u guys choose to use? thank you
Chris Hurd February 17th, 2006 12:19 AM
Hi Forrest,
I apologize for the miscommunication.
In your original post, you had asked, "what kind of lens did they use between the adapter and the camcorder." The answer is that there is no lens between the adapter and the camcorder. The P+S Technik Mini35 mounts directly to the front of the HD100. There is nothing between the camera and the Mini35.
If you are asking, what 35mm motion picture lens is attached to the business end of the Mini35, well that is covered in the article, but I'll repeat it here. It is a 27mm Cooke S4 prime lens. For more info, please see the article at this link:
http://www.hdvinfo.net/articles/jvcp...ini35test1.php
Everything else you see in the photos, from the front of the HD100 body to the back of that 27mm Cooke prime lens, all belongs to the P+S Technik Mini35. Please let me know whether or not that answers your question. If it helps, here are some more photos of the Mini35 together with the HD100:
http://www.dvinfo.net/gallery/browseimages.php?c=17
Forrest Schultz February 17th, 2006 08:35 AM
thank you for your help again, and sorry for being unclear.
My intention was to ask how does the hd100u focus its ccds onto the gg of the Mini35. normal cameras like the dvx have a fixed lens, and all we have to do is add a macro in front of it and zoom in. the hd100u has a detachable lens, meaning, whats the best way to combine zoom and macro to be able to focus on the GG. so Chris, are those pictures showing that the Hd100u has NO baynot lens attached between its CCD's and the Mini35? how is this possible to use A GG without any macro and zoom lens for the camcorder to control. I dont mean about the cine lenses, but that you for that info also. i hope im being clear. thank you for all your help Chris.
Dennis Hingsberg February 17th, 2006 08:40 AM
The answer is likely in the P+S relay lens for the HD100u itself. I use the XL2 which as you know has no fixed camera lens. My relay lens incorporates a manual iris (handy for controlling light) which also has a lens magnifier inside - likely a macro lens.
I would assume that the P+S connecting kit for the JVC also uses similar construction.
Eric MacIver February 22nd, 2006 01:42 AM
Yes, it is almost identical to the relay lense for the XL cameras. The relay lenses are basically fixed-focus lenses that are built specifically to focus in on the "flat" plane of the image resolving on the ground glass.
Forrest Schultz February 22nd, 2006 08:18 AM
thank you Dennis and Eric. how do they make sure that the camera is zoomed up all the way onto the frame? is that within the relay lens? thank you
Nate Weaver February 22nd, 2006 10:11 AM
Each relay lens (for a given camera) is the exact focal length needed to properly frame the image on the ground glass. There's no zoom. There's a specific relay lens for the XL-1/2, and a different specific one for the HD100.
The relay lens also has an iris so you can run the taking lens wide open, while still being able to control the amount of light reaching the chips. This iris is not calibrated in F or T stops, it just has an arbitrary scale for your own reference.
Tobie Marier March 1st, 2006 12:37 PM
JVC GY100H + mini35 HANDHELD??
Hi,
I am going to shoot a feature documentary next month in the middle east. My plan are shooting with the JVC GY 100H mounted with the mini35 + 2 zoom PL mount. My concern is more about the ergonomy and the leigthness of my kit than the pure quality of the signal ( some are telling me I sould go with the Xdcam as it can run at 50mgb). The fact is I wont have any camera assistant with me so with the Xdcam option, I’ll be forced to leave without any pro35 and 35mm zoomlens( it is going to be far to heavy and I need to be very light).
Now my question is the following. Is there anyone having HANDHELD shooting experience with this package? Did you use a micro force rig? If not how did you work with this package (without the handel of the basic INGzoom made by fujinon). And if you think my choice of package is not realistic for this kind of projet, please tell me why, I still have few days to turn around and find something better. Thank you
Joseph Lika March 2nd, 2006 09:00 PM
Whats up everybody
Im thinking of buying the mini35 for the HD100U... However i am not a 100 percent on this yet. Apart from some impressive samples that i've seen on this site, i havent seen any other footage anywhere else.
My primary reason for buying it would be to shoot music videos overseas, and from my calculations the mini35 plus some Cooke Primes would definitely cost me a few gees wich i am willing to spend... but im only willing to spend that much if i know i can shoot some MTV quality videos, and what i mean by that is i want to know if i can achieve the look of any video i see on MTV and will the footage look like a bigscreen movie or will it just have that soap opera look lol.
Or should i just aim for a film camera?
Dennis Hingsberg March 3rd, 2006 07:53 AM
Forrest - since the stock lenses of the Canon XL2 or JVC HD100 are removed, there is no zooming required. The relay lens from the mini35 ensures the image lands onto the CCD block perfectly. For other cameras like Sony or Panasonic YES you do have to zoom around until the image fits properly.
Joseph - True there isn't a lot of footage floating around with that combo however any look you try and achieve for a music video in my opinion is going to be done in post. HD gives you high resolution, the mini35 gives you 35mm depth of field... the rest really is up to you. :)
Check out a short film shot ONLYwith a DVX100 an no mini35: http://www.dvinfo.net/conf/showthread.php?t=45234
A guy using the Sony FX1 and homemade 35mm adapter: http://www.dvinfo.net/conf/showthread.php?t=51999
Perfect examples of two separate projects, one with a 35mm adapter and one without - yet both are highly cinematic pieces of work that were treated in post in order to obtain its look.
The real question isn't about the mini35, HD100u, XL2, shooting on film, etc... the real question is if you will be the cinematographer then who will be doing the post?
Nate Weaver March 4th, 2006 07:25 PM
It's the D.P. who creates the look, not the gear. if you aren't already making stuff that looks 90% of "the MTV look", dropping $50,000 on a Mini35 and set of S4s is not going to make it happen for you.
Guy Genin March 30th, 2006 04:16 PM
Hello Tobie,
I am not keeping track of this site often enough, even though you probably have made your decision since you posted this, I will address your questions none the less.
You must have found out that PL zooms are some of the biggest and heaviest lenses out there, they are not suitable for handheld. You would have to add a strong and heavy support to avoid damage to the mounts. Using a 35mm adaptor for your project is an added difficulty as you say you will not have an assistant with you. Pulling focus is very critical in that configuration and attempting it while operating the camera is not likely give you satisfactory results. It sounds to me that you would be better off with the original camera package.
Eric MacIver April 7th, 2006 12:04 AM
Guy answered it - BUT, there are a "few" small zooms out there... Century Optics rehouses Nikons... Haven't tried one, but they look interesting. Of course, you could also you a still camera zoom - Canon, Nikon, etc.. May fit the bill.... But run'n gun, you're still having to deal with a tight depth of field that might be better suited w/ a 2/3 or 1/3" camera.
Charles Papert April 7th, 2006 11:28 AM
Just finished a pilot with several lightweight zooms; we eventually stopped using the Century 27-80 because of focus and flaring issues (even Century admits this is not a great lens and has discontinued it). However the Angenieux Optimo 15-40 T2.6 was fantastic for wide angle work; weighs only 3.9 lbs. For those used to 10x and longer video zooms it may be inconceivable to be restricted to a 2.6x (!) zoom but in the 35mm world, it's a whole different ball of wax.
Nate Weaver April 9th, 2006 07:42 PM
Was the Century a re-housed Canon?
Danny Natovich April 16th, 2006 11:29 PM
Originally Posted by Tobie Marier
Hi,
Have a look at http://www.dvtec.tv/id29.html
Rand Blair April 19th, 2006 01:50 AM
JVC Gy 100 hd
Charles is there a web site you recommend to follow up on the Angenieux Optimo 15-40 T2.6. ?
Rand
Charles Papert April 19th, 2006 10:03 AM
There is an ad running for it in American Cinematographer I think, not sure about web presence. This seems to cover it.
Carelton Holt June 21st, 2007 08:54 AM
Looking to purchase a Mini 35 for JVC HD250
I am looking to purchase a used Mini 35 series 400 for our JVC HD250 camera.
carelton@gdiproductions.com
